02-03 Lancer Show / Shine Post your pictures, photoshops, and videos!
2003 Lancer Dome Light Too Dim
Old Jul 21, 2015 | 01:22 AM
jimbo74's Avatar
Veteran: Air Force
Does anyone have a solution for the stock dome light not being very bright?
The bulb is fine, and the wiring is fine, it just doesn't put out as much light as we would like.
I am thinking some type of LED? maybe a cluster? I want to see what the rest of you have done, so I am not spending $ on stuff that is no better than stock.....
so far... this would be the stock replacement de3175 @ 10W :
Have found:
31mm
I assume the one with 12 leds would be better than one with say 4 leds?
here is one with 24
Amazon.com: JDM ASTAR Extremely Bright 31-EX Chipsets DE3175 DE3021 DE3022 1.25 Amazon.com: JDM ASTAR Extremely Bright 31-EX Chipsets DE3175 DE3021 DE3022 1.25" LED Bulbs, Xenon White: Automotive
here is one with 4
Amazon.com: Cutequeen White 31mm(1.25 Amazon.com: Cutequeen White 31mm(1.25") 5050 4-SMD 12V Festoon Dome Light LED Bulbs DE3175 DE3021 DE3022 3175(pack of 2): Automotive
or something else all together? .... I want as much light as possible
Old Nov 3, 2015 | 07:38 PM
SilentCool's Avatar
The 31mm is better, I'm currently using it. I think the color I have is cool white (has a hint of blue), it's a huge improvement over the stock bulb. I'm considering Xenon white. Probably if I snap a pic that may help? I'm not sure.
Old Apr 17, 2016 | 07:31 PM
jimbo74's Avatar
Veteran: Air Force
were you able to get a pic of this?
Old Apr 17, 2016 | 08:20 PM
Sam Barder's Avatar
Here is what i got. 4 LEDs
Size:  102.5 KBName:  WP_20160417_012_zpsqar9jfmd.jpg
Old Apr 17, 2016 | 08:33 PM
jimbo74's Avatar
Veteran: Air Force
hmmmm..... I wonder if the 12 would be any brighter?
what brand bulb is the one you are running? Or are they all pretty much the same?
Old Apr 17, 2016 | 10:13 PM
jimbo74's Avatar
Veteran: Air Force
well, I went ahead and ordered the 12 bulb versions, will see how they work....
2 of the for $2.99 shipped from a US seller...
I think there is just 1 bulb for the dome light correct? If so, I will use the other one in the trunk (it looks like it is the same size)
DuBBzEvo27
Sep 26, 2014 07:30 PM
MrBRoced
Apr 7, 2012 07:51 PM
jonjon123
Aug 27, 2007 02:34 PM
Vroompsh
Apr 5, 2005 06:12 PM
