Gauge help!?
Old Mar 9, 2005 | 10:00 PM
nexium4's Avatar
Gauge help!?
OK I was wondering if Boost and or vacuum Pressure Gauge can be installed on non turbo Lancers. And what is the difference between Boost and Vacuum sensors.
Old Mar 10, 2005 | 07:17 AM
ski10804life's Avatar
yes you can hook a boost gauge up to a N/A car it would just be like having a vac gauge
Old Mar 10, 2005 | 07:33 AM
Daddymac's Avatar
Since there is already a thread for it....I need help installing a A/F gauge. I don't know what wire to splice into. Does anyone know?
Old Mar 10, 2005 | 07:39 AM
Lancerguy'03's Avatar
why? ther are no sensors....its mechanical.....
Old Mar 10, 2005 | 08:05 AM
blk-majik's Avatar
i'll be doing the AFR guagu soon, too. need a 2nd guage, dunno what to get. oil pressure costs a lot! not sure how the vac is really gonna help me
Old Mar 10, 2005 | 10:36 AM
sillypuddy's Avatar
a/f gauge is useless
voltage gauage is useless
vac gauge is semi-useless
oil pressure is not too expensive.. compare to a/f is about the same
-joe
Old Mar 10, 2005 | 11:16 AM
Daddymac's Avatar
Joe, thats not exactly helpful. Like I told you before...I'd like the volt gauge for when the car is at show's and the stereo is goin' so I can keep an eye on it. And the A/F gauge is purely for show but I would still like it functional.
Do you have the diagram for the harness?
Old Mar 10, 2005 | 11:41 AM
blk-majik's Avatar
-joe
a/f: ever tune a car to get the right fuel supply? its about the most commonly changed attribute. thats what the the RRM piggy does, but its still a bit rich for 93oct (which is what i use). i would use this more than anything, especially between dyno runs
voltage: yea, useless
vac: pretty important if you ask me, especially if u wana change compression or spray or do any intake manifold/plenum work.
a/f is $90. electronic oil pres /w sender is $350. i dont see how thats about the same....unless u want a mechanical and run hot oil into the cab and worry about all the extra piping
Old Mar 10, 2005 | 12:22 PM
-joe
A/F is useless if u dont haved wideband O2.
for me VAC is usefull as is EGT and AFR
Old Mar 10, 2005 | 03:45 PM
Widebody Lancer's Avatar
ok no gauge is useless. I run a volt gauge in my car off my turbo timer best thing ever the warning indicator comes on at 11.3 V for when i listen to music with the car off for hours in my shop each gauge isnt useless its just what u need what for etc...
certain gauges are better then others like a narrow abnd and wideband o2 gauges etc.... like to me a wideband o2 gauge is useless unless it does dataloggging...
Old Mar 10, 2005 | 03:46 PM
on the o2 sensor theres 4 wires u want the blue wire is the signal one is signal ground and other 2 are the heater wires....
on autometer a/f gauges the signal is purple so put purple to blue for example...
Thanks
Tory
Old Mar 10, 2005 | 07:16 PM
Red Dragon's Avatar
whats the differance between normal and wideband o2 for the A/F??? and how can you tell???
I am think about gettin a/f, oil temp, oil pressure. are theses good combo?
Also it says i need to connect the positive wire to a ignition switch how am i supposed to do that? Can i just get a add-a fuse and connect all 3 gauges to one of the fuses in the fuse box?
Old Mar 11, 2005 | 04:30 PM
Red Dragon's Avatar
Old Mar 12, 2005 | 03:52 AM
sillypuddy's Avatar
i should have put my thoughts into context.. in a car with limited space, the three gauges shown would be my LAST choices, hence uselessness.. i have space for 5 gauges and my top three was oil pressure (no oil pressure, no oil to the engine, kaboom), oil temp (did you know that our car overheats the oil under constant mivec? didn't huh? i do.. ), and water temp (not at the rad, but at the block.. overheating indicator)
for your info, i DO have a voltage gauge, but it's on the shelf until i get a spot for it and i am saving the last spot for the AEM wideband or boost gauge..
i really wanted to get EGT and IAT (exhaust and intake temps, respectively), that's why the new gauge pod hasn't been installed yet
i have tuned at least 5 V-AFCs and the narrowband o2 that comes stock on the cars are FREAKING USELESS.. you have to go to a dyno with a wideband.. but it's a very nice light show though
i am not sure which brand you brought, but i got stewart warner oil pressure and it was less than $100 cad.. granted it only has 90 degree sweep, but most of my readings are from 40 (idle) to 100 (full out) anyway, which is within range
the vacuum one i said it's semi-useless .. it's a nice indicator.. not much else.. you really can't tell if one of your vaccum hoses are lose or that there is a problem.. and it's also too dependant on where you tap into your vacuum system
the voltage gauge.. if you guys are running your car stereo without the engine running, you should consider running a charger.. when i say useless, i meant when the car is being driven.. if the volts go low enough, the car stalls anyway
Old Mar 12, 2005 | 01:30 PM
Red Dragon's Avatar
