fog light replacement
im trying to replace the fog lights but i cant seem to figure out how to get to the bulb. im pretty sure i have to take out the 3 screws on that metal casing behind the glass (?) but the screws seem to be stripped...
Yes, you have to take out the 3 screws in the metal case. They do strip easily, and the screws are VERY tight. If they're already stripped, you'll probably have to drill the heads off them and use vise-grips or pliers to unscrew the shaft that'll be left over. Find a decent hardware store that carries metric fasteners, and match up thread sizes with the pieces you removed.
Good luck.
Good luck.
Instead of drilling the head off the screw my suggestion would be to buy a stripped screw removing drill bit from a hardware store. I stripped the screw on the o2 sensor for my CAI and the drill bit removed it effortlessly.
