MAS screws stripped.
Old Sep 10, 2006 | 12:14 PM
zionphunk's Avatar
One of my MAS screws are damn near stripped, i was planning on buying a SRI but if i cant get my MAS off what am i gonna do? anyways, does anyone no a way to get it off without me stripping it more? thanks.
Old Sep 10, 2006 | 12:59 PM
AdamRA's Avatar
I used a pair of pliers....I also had this issue and my car was near new when I put my intake on. Those screws are such garbage
Old Sep 10, 2006 | 01:01 PM
k3lv's Avatar
yeah use pliers that don't have the jagged grip, cause those will strip them even more starting on the outside.
Old Sep 10, 2006 | 03:51 PM
Myszkewicz's Avatar
As an absolute last resort, you can *carefully* drill the heads off the screws, and then use pliers or vise grips to remove the protruding stud after you take the MAS off. Then go to a decent hardware store that stocks metric fasteners, and get some good screws of the same size/length/thread pitch.
Old Sep 10, 2006 | 04:01 PM
LancerChicka84's Avatar
i stripped mine and just ended up drilling them out which was no problem. and then i used some screws i had layng around the garage.
THANKS
Old Sep 10, 2006 | 05:41 PM
glanceri2's Avatar
the pro way is to just use a vice grip. so EZ!
Old Sep 10, 2006 | 06:19 PM
ralliart329's Avatar
I got out a saw and cut the MAS off after taking the whole box out of the car
, then pliers from their.
Old Sep 10, 2006 | 06:41 PM
zionphunk's Avatar
cool, thanks for the tips guys and gal
Old Sep 11, 2006 | 06:05 PM
morpheus256's Avatar
another option is hack saw, put a "slice" into the head of the screw, then use a slotted screw driver to remove them
Old Sep 12, 2006 | 03:53 PM
Joyrider's Avatar
yeah the dremel is your friend with bad screws... make a line and use a screwdriver !
that s the best, then replace the screws
Old Sep 12, 2006 | 07:19 PM
lanzerralliart's Avatar
EvoM Super Moderator
if you guys and or girls are replacing them make sure to get stainless steel ,if not you'll run in to this problem again.........
Old Sep 24, 2006 | 11:15 AM
rdc's Avatar
rdc
I ran into this problem also. I found out at the hardware store that phillips screwdrivers have 3 sizes of drives (kinda like ball point pens); when you use the wrong size one, you will end up stripping the screw, so be sure to use the finest one for the MAS screws or else it will become a PITA.
blown1
Dec 15, 2010 01:54 AM
Mellon Racing
Feb 1, 2009 08:03 PM
lanceracer
Jan 18, 2005 08:11 PM
herdfan2005
Jan 18, 2005 04:00 PM
nubby
10
Sep 11, 2003 06:02 PM
