Temp Gauge
Old Apr 22, 2009 | 03:54 PM
gabep88's Avatar
Temp Gauge
Ok i have gone through most of the post here and still can find what to do with or were to place my temp gage is mechanical i know i dicided do in it the hard way if any ine call help me i will post the pictures after being done.. Thanks
Old Apr 23, 2009 | 11:04 AM
03_Lancer_ES's Avatar
Sounds like you need either a radio relocation kit, which allows your radio to be installed where the cubby hole is below the HVAC controls, therefore giving you the ability to install gauges where the radio used to be. Or you can get a plate that installs where the cubby hole is allowing you to place gauges there, OR you can get a pillar pod which replaces the pillar from the dash to the roof along the windshield with gauges OR you can get a steering wheel top mounted pod OR you can also get a dash top gauge pod.
Old Apr 23, 2009 | 11:32 AM
gabep88's Avatar
ok i will try that, and i have a triple gauge and i put it just bellow the ac and it fits perfect ones everything install ill post the pictures in this tread
Old Apr 23, 2009 | 11:35 AM
gabep88's Avatar
by the way thanks very much
LB_Reddy
Evo X How Tos / Installations
Jul 2, 2016 01:40 PM
500whp.com
87
May 31, 2016 01:30 PM
tscompusa
Jan 10, 2013 11:34 PM
fbrs
May 11, 2012 06:16 PM
Appauldd
Feb 23, 2009 08:05 PM
