RRM Tie bar install questions
I am new at this whole tuning thing. So I was wondering if anyone has any pictures of the tie bar install to help me out. I have already read over the how to install. I just wanna ensure I am removing the right stuff. The tie bar is installed between the two camber bolt in the center of the car at the rear where the to arms meet correct?
Correct. All you do is remove the nuts from the camber bolts (mark them before removal so you can be sure you don't mess up your alignment), slide on the bar, then reinstall the nuts (89 ft/lbs.)
michael2014
Feb 2, 2016 04:40 PM
