Only Run Fog Lights...
Update: playing with it a bit and some reading.The way it works is that the fog switch sends an request from the ECU to the front ecu to ground and un ground the lights to make them work... its more in depth then it needs to be. so atm the deff most easy way to doit is to make the ground on a switch as stated before..
if anyone wants to doit that way wile i figure another solution ill be more than happy to make a write up for it with pics and all... for now im still workin on a better way to doit with out a bunch of wires and such.
non as of now but i did notice that when you take the multi meter and run a wire from the top right pin if your standing in front of the car that when you turn the fogs on after you turn the head lights on if the wire is attached to the positive of the multi meter it lets your turn the lights off and the fogs stay on untill you remove the wire from the meter. i think this can be adapted to a second relay that you can wire to the stock switch to turn off the wire. im looking into it more now it might be a better solution then the other way.
CWBs05LancerES
Sep 17, 2016 07:13 AM
04, box, evolutionm, fog, fog lights, fuse, lancer, light, lights, mitsubishi, ralliart, removal, run, swich, yellow bulbs
