Split Second FTC01
Old Apr 18, 2010 | 05:00 PM
Boushard's Avatar
Split Second FTC01
Hi guys,
a members of my club ask me to install is piggyback on is 05 RA, everything is fine until I saw the huge box coming out of the package. This monster doesn't look like my splitsecond PSC1.
The box he have is a splitsecond Fuel/timing controller (FTC01-077 to be precise) I tried to search over the splitsecond web site to have the wire colour code for this specific unit but it doesn't exist. So I look on another model and look the colour and everything seem to be the same colour as the psc1. So I tried to plugged the controller and test it. I follow the DangerousDan how-to and use the crank position sensor at the first attempt
After the plugging and uploading the fuel map, I fired up the engine and the RPM show 10000RPM and the MAF Voltage show 2.0v and doesn't variate even if I give gaz. So I've tried the tach signal after this, the RPM showed up correctly but the MAF Voltage don't variate and stay at 2.0v.
After a few attempt I disconnect the unit and bypass de MAF signal to get back to normal.
The question is, How can this unit can be plugged on a 05 Ralliart, if it can be plugged.
Thanks for future information
Boushard
Old Jun 13, 2010 | 10:56 AM
Boushard's Avatar
No one have ever see/use this box on a RA!?!?
Old Jun 13, 2010 | 01:24 PM
lanzerralliart's Avatar
EvoM Super Moderator
Where did your friend buy it from? The source would be a good start.. Do you have any pictures?
daveheit
Jul 21, 2016 01:14 AM
BlackRaven
Mar 15, 2013 09:45 AM
mace1890
Lancer Aftermarket Forced Induction Tech
Sep 20, 2011 10:19 AM
GTVEVO
AEM EMS
74
Jul 5, 2011 10:46 AM
vtluu
Oct 24, 2004 07:43 PM
