maf sensor
Old Sep 26, 2014 | 05:41 AM
rafa.ralliart's Avatar
maf sensor
Hey I got a lancer ralliart 04 and im wondering if the maf from a eclipse 3.8 will work better or wor on my ralliart ?
Old Sep 26, 2014 | 07:35 AM
CrAnSwIcK's Avatar
work better how? it's just a sensor. it either works properly or doesn't...it's not really a matter of better or worse.
Old Sep 26, 2014 | 09:36 AM
maf sensor
Im asking cuz I want to knw if the air/fuel ratio gonna be the same as the stock so that's y im asking cuz I knw it is just a sensor but I want to knw if that maf sensor from the eclipse 3.8 mivec will work on my car better than the stock one
Old Sep 26, 2014 | 09:37 AM
Work better on my air/fuel ratio
Old Sep 29, 2014 | 09:21 AM
CrAnSwIcK's Avatar
i still don't know what you mean...
Old Sep 29, 2014 | 03:27 PM
Ok let me explain this for u ... im trying to change my map sensor and thast the one that control the air that going in and the fuel as well ... so in trying to change the map sensor from my 04 ralliart for one map sensor from a eclipse 3.8 to see in my car pump more gas because I got a big throttle body and I got to mush air so I need now more gas to habe a rich mix or regular mix so im wondering if the map sensor from the 3.8 will help or not
Old Sep 29, 2014 | 03:30 PM
And both map sensor got the same numbers except the bottom ones
Old Sep 29, 2014 | 03:31 PM
Raikiri's Avatar
I dont see how it would make a difference. The ECU is the one that will determine your AFR. It's going to read a certain amount of air irregardless of what sensor it is. Are we talking about MAF or MAP sensors here?
Old Sep 29, 2014 | 03:48 PM
The one that go behind the manifold Map sensor sorry
Old Sep 29, 2014 | 03:52 PM
Look the video thats the sensor on talking about but I got the sensor from a v6 and I want to knw if that work better that the stock one
http://roadracemotorsports.com/store/index.php?main_page=product_info&cPath=1_5_13&prod ucts_id=448
Old Sep 29, 2014 | 09:28 PM
CrAnSwIcK's Avatar
a map sensor doesn't read airflow, only absolute pressure...if the engine is normally aspirated, it doesn't matter which sensor you use, because the manifold will only experience vacuum with no throttle input, and regular atmospheric pressure at wide open throttle...they should both be 1 BAR map sensors...
Old Sep 29, 2014 | 10:25 PM
Raikiri's Avatar
I wonder why he chose the 3.8L TB. That's the GT Eclipse TB right? Cranswick don't you have the same one or was that lanzer?
Old Sep 30, 2014 | 05:53 AM
I choose that tb cus the stock one it is 60mm and that one is 65mm and I get more air but I need more gas and a flash fir my ecu or some ship or something for the ecu cuz where I live no one work with this ecu
Old Sep 30, 2014 | 10:01 AM
Raikiri's Avatar
There are no chips for this ecu. The only flash available you'll have to talk to Hackish. I dont think there's any benefit of the 65mm vs the 63mm TBs just because your intake manifold inlet is still only going to be 63mm either way and that's all that will be let in having smooth flow.
Old Sep 30, 2014 | 09:21 PM
Ok
