found a good system
Old Jan 24, 2005 | 06:33 PM
DiamondWhite's Avatar
found a good system
my friend and i decided on this system
2 Adire Brahma II's 12"s
2 viper 1200.1 Amps
and a pioneer AVIC-N1 Head unit
Old Jan 24, 2005 | 06:54 PM
SeanT's Avatar
all i can say is good choice with the avic-n1! thats what I have and i love it! good luck with your system
Old Jan 24, 2005 | 07:18 PM
tuffguy's Avatar
How much is that gonna cost? (if you don't mind me asking)
Old Jan 24, 2005 | 07:32 PM
pinoynoskillz's Avatar
hey diamond white check your PMs
Old Jan 24, 2005 | 07:33 PM
lol i don't care... i'm very open..
the brahma's are rated at 1600watts RMS EACH!!!
and only cost $400 each... which isn't bad
the Vipers are roughly $200 each (Refurbished boxes had a tear.)
and the Pioneer is i think 1,350
I'm still thinking i need a battery in the trunk (optima goldtop), wiring(+accs)
Plus i'm looking at some tweeters and CDT complete aftermarket interior speakers to swap out the infinti's
Old Jan 24, 2005 | 07:36 PM
hey those brama's are 1600w RMS each. its max peak power is probably 1600w but the bet is they are at most 400 rms. if you check your pms... look at what i wrote.. my subs are also 1600w peak power @ 400watt rms @ 4 ohm with the amp i told you about.
Old Jan 24, 2005 | 07:38 PM
lol
www.adireaudio.com
They are 1600w RMS 4800w peak.
Param
10" 12" 15"
Fs
30 Hz 28 Hz 26 Hz
Qms
4.7 5.1 5.5
Qes
0.44 0.47 0.51
Qts
0.40 0.43 0.47
Vas
18 liters 38 liters 113 liters
Znom
Dual 2 Ohm voice coils
Re2 1.4 Ohms DC Resistance per voice coil
Le3 0.9 mH per voice coil
BL
15.9 15.9 15.9
Sd
300 cm2 436 cm2 749 cm2
Xmax
29mm one way linear
Pmax4
1600W RMS, 4800W peak
NOTE: Power rating is thermal only! It is NOT a power requirement; typically you get full output with significantly less power than the rating. SPL5 82.3 dB @ 1W, 1m 84.4 dB @ 1W, 1m 87.6 dB @ 1W, 1m
Diameter 10.5" 12.5" 15.5"
Cutout
9.25" 11.125" 14.125"
Depth
6.875" 7.25" 8.75"
Volume
0.11 cubic feet 0.15 cubic feet 0.18 cubic feet
Weight
37 pounds 39 pounds 41 pounds
Price
$349 $379 $439
1 - This is the nominal impedance of the driver. Each voice coil is 2 Ohms nominal; series connection would be 4 Ohms nominal
2 - Each voice coil is 1.4 Ohms; series connection would be 2.8 Ohms
3 - Each voice coil is 0.9 mH; series connection would be 3.6 mH
4 - Pmax is the maximum continuous electrical power; mechanical power handling is COMPLETELY dependent upon the application, and can be considerably lower than the electrical power handling. Pmax is NOT a "required" level of power for a driver. We rate per IEC 268-5.
5 - This is true reference efficiency; for voltage sensitivity at 2.83Vrms, add 3 dB for series (4 Ohm) wiring and 9 dB for parallel (1 Ohm) wiring"
Old Jan 24, 2005 | 07:45 PM
oh well.. i think i still have a better deal LoL. i blow the living crap out of JLs lol. =\. good luck tho.
Old Jan 24, 2005 | 07:59 PM
Lol thanks!
Old Jan 24, 2005 | 08:28 PM
tuffguy's Avatar
Wow, that look really sweet... a tad out of my price range. =P
Old Jan 25, 2005 | 11:39 AM
Mine too... but ... this car is going to get decked... engine and audio... then visual
Old Jan 25, 2005 | 04:38 PM
TeamAccolade's Avatar
lol don't post a new rear deck bouncing thread....! it will happen... i suggest getting it down some how.
Old Jan 25, 2005 | 07:52 PM
easy... take oak plywood reinforce your rear deck and use your rear seats as sub enclosures.. use your subs as free air types. if i decide to keep my setup.. that'll be done on my car (=.
Old Jan 26, 2005 | 10:47 AM
i'm probably going to get it all professionally installed since i know squat about audio electronics.
