Recomendations for a new CD Player HU
Originally Posted by Frozenrock
blue wire is usually power antenna which you connect to power your amp.
Use #1: Replacing the OEM (factory) radio
Replace the factory "INFINITI" Radio with a higher quality aftermarket radio. The interface connects into the male 6 pin DIN plug that is normally plugged into the OEM (factory) head unit. The interface BLUE wire is then used as the remote turn-on lead for the OEM (factory) amplifier."
Konakev
Oct 30, 2016 01:20 PM
Lancer_Man7
May 14, 2004 03:18 AM
