Candy
Datzun ZG fender flares. I'll get the measurements for you next time.
Rims are 17x9 +22 offset. They're Varrstoens.
Tires are 215/40/17 General Exclaims.
If anything I want to get new wheels with a lower offset so that the wheels will be flush with the flares. Right now the wheels sink a little in. Also get wider tires. Rims are already on spacers from previous owner and I'm afraid to add more lol.
i think ur right about wider tyres because your 200+ pony are need this
btw i recentrly subscribed to your instagram profile, try to update it more often
Most recent pics when I washed it couple weekends ago.
https://imagizer.imageshack.us/v2/75...90/59/kd3y.jpg
https://imagizer.imageshack.us/v2/75...0/706/cqoe.jpg
https://imagizer.imageshack.us/v2/75...0/841/hd7f.jpg
https://imagizer.imageshack.us/v2/75...0/703/8zsy.jpg
I'm subscribed to the thread but I hardly ever come on here. No flickr account but I'm on revscene.net underneath the same name. Instagram is Final_Bauce but I only have 2 pics up haha. I haven't invested anymore money into the car, mainly because I'm still living at home and my priority right now is to save up to move out haha.
Car is looking good! You should come around here more often, your the owner of one of the sexiest RA's on the forum!
I don't remember there being any tuning issues. He must have fixed them before he sold the car to me. I had one problem with a crankshaft sensor (I think) which caused the car to stall out and die all of a sudden. Happened a couple of times on my way home.
I'm just trolling you, lol...it's the RRM turbo kit no?
the setup is not fueled correctly or evenly, and the ECU doesn't even have boost tables, so there's no way of delivering the correct amount of fuel based on boost pressure...you risk blowing the motor, not because "nothing lasts forever" but because under boost, the RRM setup can't deliver enough fuel evenly to all cylinders for normal combustion, and you risk having detonation in cylinders 1 and 2 because they are the farthest from the throttle body, which is where your extra fuel is coming from, as opposed to being injected directly into the runners as multiport fuel injection is designed.. With ECU tuning you have 4 larger injectors, and a MAP sensor, and the ECU "knows" when there's boost and can fuel accordingly.
, but is there anything I can do to fix the problem?
Does look awesome best ra I ever seen. Did u ever think going wingless?
As what crank said id say changing the ecu to one where you have full tuning options.
I know you said you didn't want to put any more money into the car, and it's not like it needs anything more anyway, you got probably the sickest RA's going, but I'd hate to see that beauty get her heart broken. It would be a little pricey, but you're looking at removing the 5th injector and plugging the port, or replacing the elbow that connects to the throttle body, getting 4 larger injectors 440cc I would say minimum, a 3 bar MAP sensor, and then the tuning, with tactrix cable. It's actually too bad, but Fastworks (hackish's software/company) just had a spring sale a few weeks back, $200 off the normal price for the software and base tune. but you're looking at around $1,000 for it all, depending on the injectors it could be more...but I would maybe talk to hackish about.
I measured the fender flares. Theyre 4inches in the back and 3inches in the front. Should mention that the fenders were cut and the flares were cut by a shop so that they would fit.
I actually want a big GT wing!
just food for thought
Well I hardly ever hit boost. No need to since I'm mostly city driving. Then again... Nothing lasts forever.
