04-06 Ralliart Aftermarket Forced Induction Tech (aftermarket turbo/supercharger related topics)
Forged internals
Old Feb 13, 2005 | 08:13 PM
DiamondWhite's Avatar
Talking Forged internals
along with the 3000 companies i plan on calling tomorrow... i'm going to get pricing on Ross Pistons and Crower Rods... i will be turboing this car... and i'm going to push it to the max eventually... couple of opinions i need
What ratio should i get the pistons? 8.5:1? 9:1? 9.5:1? I usually hear that 8.5-9 is the sweet spot... so would 8.75 be a valid size?
also what should i look for on the rods... i'm not 100% sure what i'm looking for but i wanna upgrade the internals.. and some other things then i'm going to go dive into a turbo so i can max performance once i can afford it.
Old Feb 13, 2005 | 09:53 PM
lrh35's Avatar
From what I hear 8 - 8.5/1 is best but I really wouldn't know.
Old Feb 13, 2005 | 11:12 PM
a friend told me 8:1 makes the most power, but 8.5:1 makes alot without the turbo too. Maybe i'll redo the engine if i upgrade the turbo's enough.
Old Feb 14, 2005 | 05:55 AM
blk-majik's Avatar
correct me if im wrong here, but this is how i understand it:
if you wana turbo, you need a lower compression because the pressure is already increased in the manifold before it gets compressed by the pistons. adding aditional compression in the cylinder would multiply the amount of boost you are running. GOod for power, bad for the block if you keep it too high. By lowering the work the pistons have to do, you take some stress off the entire system. But, if you go too low you might have ignition problems. I think malvin used 9.5:1 to get his 400whp.
For NA, you want higher compression to give more power by pushing as many molecules of fuel/air as close together as possible. but if you go too high, the engine may struggle to turn over or idle poorly.
So, idealy, two sets of pistons would be needed to allow either application. a 12.5:1 - 14:1 would be nice for NA. i think a 9.5:1 or maybe even a 9:1 would be nice for boosting. when u talk to them, ask for their oppinions on a 2.4L 4cyl with target HP ratings of X.
Old Feb 14, 2005 | 06:51 AM
Lol T-Minus 30 minutes till phone-a-thon '05
Old Feb 14, 2005 | 07:09 AM
blk-majik's Avatar
good luck and keep us posted =)
Old Feb 14, 2005 | 07:25 AM
trust me ... i'll be a post ***** :-D
Old Feb 15, 2005 | 10:13 PM
MitsuRalliArt's Avatar
WTF, the main reason for higher or lower compression is decreasing detonation or reducing the need for HIGH octane gas. High as in 100+ octane. More compression is equal to more power. But that power can get annoying if you can only run 100+ octane on the way to work.
If you plan on going hardcore turbo 20+ psi, consider the 8:1. Otherwise 8.5:1 is sufficent if you are running a properly intercooled setup.
Old Feb 16, 2005 | 07:19 AM
i found another 2.4l Mivec engine... 2k miles... perfect condition.... (rear ended) i'm going to get that block and try to do a complete rebuild and turbo it. then drop it in... lucky for me it's not a daily driver... woop woop
Old Feb 16, 2005 | 07:29 AM
blk-majik's Avatar
wow, nice find =) while its not in running condition, send the pistons and rods out to have some diff compression prototypes made and maybe talk them into entering them into the product line =)
try here: http://www.wiseco.com/sections/automotive.html
Old Feb 16, 2005 | 08:07 AM
yea... i was checking with Rosspistons... still waiting on an email back.
Old Feb 18, 2005 | 04:48 PM
cleotis's Avatar
let us know what you hear I am very interested.
Old Feb 18, 2005 | 08:35 PM
MiVecJohn's Avatar
Go W/ Pauter Rods!!!!
Old Feb 18, 2005 | 11:58 PM
AdamRA's Avatar
Link?
Old Feb 19, 2005 | 12:00 AM
blk-majik's Avatar
wow im a smartass
http://www.google.com/search?q=pauter+rods
