04-06 Ralliart Aftermarket Forced Induction Tech (aftermarket turbo/supercharger related topics)
Injectors
Old May 18, 2005 | 01:23 PM
Ralliart403's Avatar
Injectors
What are the stock injectors in an 04 Ralliart?
What should I have to run my turbo? <--- and where do i get them?
Is the fuel rail "stock" in our car good enough ?
Old May 19, 2005 | 06:33 PM
Myszkewicz's Avatar
305cc, judging by the number on the side of them: HDA305E
That depends on how much boost you're planning to run, and how close to 100% duty cycle the injectors run in a stock car. If you put in larger injectors, you'll need some sort of fuel management to compensate when you're not boosting. Unfortunately, in order to boost enough to make a turbo install worth it (IMO), you'll need injectors. I wonder if stock turbo DSM injectors would work..?
Unless you're going after insane power, yes. For the ~250hp you'll maybe have with your turbo, the stock rail is more than adequate. If you're running out of fuel, a more likely culprit would be the fuel pump or injectors.
Old May 19, 2005 | 08:15 PM
Thank god out of all those people who have looked at my post finally someone replied! but yes I am going after as much power as possible! My one friend has a 6th gen celica thats dicustingingly fast all custom work.. my other buddy has an STI with a t67 turbo stand alone fuel management the freakin works and I have to keep up with these guys!! lol I cant let them blow me away!
Old May 22, 2005 | 07:11 AM
Thunder-rush's Avatar
Stock injectors will be good for 4-5psi. After that you need at least 550cc for 7-8psi this is with the returnless system. With a 225 walbro fuel pump and regulator return system the 550's will hold to 12psi for 11.8-12.4 A/F ratio.
Old May 23, 2005 | 12:31 PM
ModernRacer's Avatar
i'm gonna be running 650cc injectors, i plan on running 17psi on high setting and 7psi on low, but 17high rquiers 103 octane, and i already built a larger fuel rail to compensate for the fuel needed, so it all comes down to how much HP you want to put out, i'm gonna be aiming for roughly 400+ hp,but mind you i'm investing lots of $$ into this project. So you'll need a stand alone unit for sure,either way.
Old May 24, 2005 | 05:13 AM
Modern, Did you installed a return system or is it returnless..?
Old May 24, 2005 | 06:26 AM
no i didn`t install that sort of system, the Ralliart doesn`t have a return fuel system so you can`t use a FMU on the fuel system. So i will have to work around this,but i should be no problem.
Old May 25, 2005 | 05:22 AM
I heard that a returnless system sucks for what we are looking to do to my car.
doesnt anybody know where i can get a return feed fuel rail? and those 550 injectors where can I get those? Could I run my car with the 550 injectors without the stock fuel pump or do i need a better fuel pump?
Old May 27, 2005 | 09:53 AM
DallasN2O's Avatar
Anyone know if theres a direct replacement upgrade for our fuel pump? I know some guys are using walbro 255's but I want to know if you have to mod it to work or not. Also, does anyone know what injectors RRM uses for their upgrades?
Old May 27, 2005 | 12:43 PM
nope no modding needed it`s a direct replacement, plug & play so to speak, i have one in my car, was easy to install.
Old May 27, 2005 | 03:41 PM
DallasN2O's Avatar
Since you upgraded your fuel pump what else did you have to do when you installed it? Why did you need the more flow? Nitrous? Turbo? Whats our stock fuel pressure? Will any walbro 255 pump work? Are there any injectors we can use as upgrades?
Old May 27, 2005 | 04:11 PM
otter's Avatar
EvoM Administrator
Call your local Mitsu dealership and ask them for the injector part number for the Ralliart (you can find the Evo part number by searching). Wincaps is telling me that the Evo injector and the RA injector are the same, but I'm not positive that's right. Only thing I'm 100% positive on is that the Evo and RA use the same o-rings and insulators.
Old May 27, 2005 | 04:16 PM
ok first off........too many questions, the simplest reason why i changed the pump is for more steady flow, second I am going turbo in the Spring of 2006, and as for injectors, i will be purchasing a set of RC injectors, they are one of the best injectors for the ralliart and not too pricey.
Old Jun 1, 2005 | 08:10 PM
Where do I find RC Injectors?
Old Jun 14, 2005 | 08:39 PM
DallasN2O's Avatar
what does fuel pressure go up to after the 255 is installed? Do I need a FPR?
