04-06 Ralliart Aftermarket Forced Induction Tech (aftermarket turbo/supercharger related topics)
Injectors
Old Jun 20, 2005 | 06:57 PM
MitsuJoe's Avatar
You probably need a FPR. I doubt the stock ralliart regulator can handle a 255. I think they make a 190 which may be better suited for a RA. Or even a stock EVO pump.
Old Jun 22, 2005 | 06:38 AM
Thunder-rush's Avatar
First off, RA injectors are high impedance and EVO's are low will not work. RA f-pumps might have a regulator built-in that will allow up to a certain fuel pressure while EVO's or aftermarket need an external reg. If I where to install a walbro 255 with returnless probably the F-press will go up considerably and the pump in the long run will be damaged bc's the fuel doesnt flow back to the tank and its struggling to push back the excess fuel that's not squirted by the injectors. If the pressure is controlled by our ecu by means of variable voltage sent to the pump and not by an internal regulated pump then it might or could work.
2Cnts
Old Feb 20, 2006 | 09:56 PM
ccmunkey's Avatar
Stock Fuel Pressure
When I added my 50 wet shot i was concerned about stock fuel pressure. the fuel pressure guage i added inline gives a steady reading of 55psi at idle. it's kinda hard to check the gauge under the hood when under load on the road. will check next time i hit the dyno tho
Silver_Hawk09
40
Nov 29, 2017 12:14 AM
hussein
Feb 17, 2017 11:11 AM
rafa.ralliart
04-06 Lancer Ralliart How To Requests / Questions / Tips
Oct 24, 2014 02:58 PM
shane4
Oct 19, 2011 10:53 AM
DClipse
17
Mar 19, 2008 09:26 AM
