04-06 Ralliart Aftermarket Forced Induction Tech (aftermarket turbo/supercharger related topics)
Fuel CUT
Old Mar 22, 2006 | 07:32 PM
Ralliart403's Avatar
Fuel CUT
Sorry I forgot to add to my other post. Will my car hit a fuel cut at a certain psi of boost on the stock ecu
Old Mar 22, 2006 | 08:04 PM
ThunderOZ's Avatar
Well, unless you get it moved up then I would assume so...
Old Mar 22, 2006 | 08:41 PM
PR_Mivec's Avatar
the cut will not be determined by the boost but by the rpm either way too much boost wo/ fuel will lean the car and f-it up...
so if you want to control fuel do the logical thing..
buy a evo 8 fuel rail (yes it fits, stock or aftermarket), a regulator
and run the line so you can control fuel pressure
that was for free
Old Mar 22, 2006 | 09:05 PM
boozeup&riot's Avatar
PR_Mivec > *
some nerdy schtuff for ya there.
Old Mar 22, 2006 | 09:09 PM
PR_Mivec's Avatar
Old Mar 23, 2006 | 07:14 AM
so an evo 8 fuel rail will fit on a RA???? is it a returnless system too?
Old Mar 23, 2006 | 11:59 AM
amg_dragon's Avatar
If you plug the return line hole it is. It's much easier to convert from return to non return than it is the other way around. So make like a scene from Carrie and plug it up!
Old Mar 23, 2006 | 12:29 PM
PR_Mivec's Avatar
no.. the system on the evo is with retun ergo you can control pressure w/ regulator...
Old Mar 23, 2006 | 06:37 PM
What did you do? Do you now have a return system on your car? And if yes how did you get the fuel line to return back into the tank?
Old Mar 23, 2006 | 07:22 PM
I could totally be talkin outta my a$$ here but it sounds to me like he put an evo 8 fuel rail on with an fpr and a new fuel pump. With the new fpr and pump he now has a return system...? I'm a bit new to trying to figure all this stuff out so I apologize if I'm way off base.
Old Mar 23, 2006 | 08:24 PM
PR_Mivec's Avatar
sighs*
instruments needed...
evo fuel rail, stock or aftermarket...
regulator (for evo)
a retun line from the rail to the tank how is this done.. god invented fittings, the drill and bits... drill the tank put a fitting to the tank, make sure you make a good seal.. put the line in the fitting and you are done..
Old Mar 24, 2006 | 12:12 AM
Sorry, I guess I should have elaborated more. I assumed that you were running back from the rail to the tank, I just thought you had the aftermarket pump in there also.
Old Mar 24, 2006 | 06:45 AM
mitsutech005's Avatar
YAY!!!!! lol and it was soooooo simple. i was trying to over analize things to solve my fuel problems, damn. your my hero. fuel hike fuel hike la la la la la la!! hooorah!
Originally Posted by PR_Mivec
sighs*
regulator (for evo)
Old Mar 24, 2006 | 10:43 AM
PR_Mivec's Avatar
well i do have it all, so im guilty on all charges
btw i wasnt bashing so sorry if i sounded that way...
Old Mar 26, 2006 | 05:52 AM
Man that sounds like it could be pretty dangerous messin with the gas tank with drill bits (metal on metal =sparks with gas?) even if I emptied the gas tank out, what could be some problems I could have? I mean if something was wrong. How did you do yours?
