I am Offically BOOSTED!
Ok, i getting a new camera this weekend so pic's will be forthcoming. As far as the car. It's like driving a different car. I love it. It idling smooth and boosting great. Lots and lots of pull. However, I do get the odd minimal backfire sound when coming out of second and into third at speed. Nothing very noticible unless you are paying attendtion. I'm not sure what is causing it?
Finally got my camera and cpu working together nicely.
As promised here is a copy of my actual dyno results.
Notice I peak my trq numbers at about 4600 rpms and max out on horse power at around 5600 rpms. You can also see the MIVEC switch over at just over 3750 rpms
My car is currently set up almost identically to the RRM shop car when it was dyno'd last year.
My car has the RRM turbo kit, custom magnaflow axle back and UD pulley. Running 91 octane pump gas and it has been consitently hitting 7 lbs of peak boost. The only real difference b/w the two is atomosphere and altitude. RRM dyn'd at 266 ft above sea level at approx +20 degrees celsisus and edmonton is 2200 ft above sea level at aprox +5degrees celsisus.
IIRC, the RRM shop car if I recall dyno'd 215.19 whp and 217.12 lbs/trq.
My car dyno'd at 214.91 WHP and 221.77 lbs/trq.
see, GDS's car is wooping yours on the dyno
he got almost that on a mustang dyno (unless that's what you dyno'd on, still can't see the images
