04-06 Ralliart Aftermarket Forced Induction Tech (aftermarket turbo/supercharger related topics)
Pistons and other internals
Old Jan 7, 2008 | 12:27 AM
chowetime's Avatar
For those that have rebuilt the internals on there cars what other parts did you upgrade beside the pistons... did you also replace the rods and decompress the engine as well and what were the results
Also what type of pistons did you use forged or ????
Old Jan 7, 2008 | 06:23 PM
DClipse's Avatar
I'm wondering the same thing. I think someone said that 4G63 rods will work on our cars. Is that true?
Old Jan 7, 2008 | 07:53 PM
RALLIevoLUTion's Avatar
i believe its the 2ndgen 4g63 rods
i been researching my self found some sites for rods http://www.atomicspeedware.com/rodmiteag.htm ...and has anyone purchase piston from this site? http://www.importperformanceparts.ne...itsubishi.html
Old Jan 7, 2008 | 08:19 PM
SSP-Ralliart's Avatar
you have to remember that our throw is longer plus i don't know if the main caps on the connecting rods are the same width as ours. I am engineering my own. I can make my own crank and custom pistons also. I am going to research alittle bit more to see the similarities between our rods and those from a 4g63. Plus our jornal size may be different. Lots of things to consider.
Old Jan 8, 2008 | 01:47 AM
Cow town racer's Avatar
The connecting rods fit, I'm 100% certain on this and it has been done before. I have dug it earlier, and any second gen or later, rods will fit our car.
Old Jan 8, 2008 | 06:45 AM
DClipse's Avatar
Man, if that's true that would be great. Anyone on the site have it?
Old Jan 8, 2008 | 12:37 PM
not anyone anymore, but the first person to turbo the ralliart used them with no problems. Search for TURBO TECH PR and you will find it if you look hard enough.
Old Jan 8, 2008 | 12:56 PM
DangerousDan's Avatar
I'd recommend reading all of his posts, FTW
Old Jan 8, 2008 | 12:58 PM
+1
Old Jan 8, 2008 | 11:42 PM
chowetime's Avatar
Sorry I am going to be nasty here but can we keep this very accurate as to what has been done and the results... reason being things get clouded and miss read when we start say "so and so did this to his car but he is not on this forum anymore..." not the useful info I am really chasing. I am after very precise info from people that have done this type of work.
Old Jan 9, 2008 | 12:26 AM
Then look it up yourself, the info is all right in front of you. You have the search tool just like the rest of us.
Old Jan 9, 2008 | 04:27 AM
+1, you want it from the horses mouth and we gave you the horses name. you do the math, Christine, because last time I checked one plus one was still two.
Old Mar 31, 2008 | 06:58 PM
silversleeper's Avatar
Sorry,
Christine, here you go. Hope its not to late lol. I havent been on here much since I am stuck here in IRAQ!!! I am currently getting parts together to do a bottom up build when I get home soooo here is the confirmation on the rods you was looking for.
https://www.evolutionm.net/forums/sh...&highlight=rod
Old Apr 17, 2008 | 04:20 AM
RALLIART15's Avatar
Next question I have found rods and JE pistons will custom make pistons for our black and evo rods but what bearings will fit, any help is greatly apreciated.
Old Apr 17, 2008 | 05:39 AM
Jokiesmurf's Avatar
Piston is our geatest weekness. ur rods can handle 15psi I been told. But with all our traction issue to much boost 12 to 15 ain't making it. So I went the piston route from Ross 8.5 to 1 compretion & 1mm bigger or wider.
