04-06 Ralliart Aftermarket Forced Induction Tech (aftermarket turbo/supercharger related topics)
Pistons and other internals
Old Apr 18, 2008 | 04:46 AM
ModernRacer's Avatar
i did a bunch of research on this subjet, for one the bore and stoke specs are clearly noted in the back of your owner's manual, as far as i know the rods can be purchased though Eagle and the pistons from the older generation Talon's can be had by Aries, as long as you have the proper specs they will sell you the ones you need, the stock crank is good for up to 800hp so no issues there. Me personally if i had the choice i would do a stroker kit upgrade, so go 30 over and "I" beam rods, so then you would be good for at least 600 to 700hp and then turning up the boost pas 10psi will not be an issue
3gevoclipse
Oct 12, 2015 11:33 PM
Rmatthew987
Jun 18, 2012 08:43 PM
lillev23
Feb 25, 2011 08:31 AM
Jrod@Buschur
Nov 5, 2008 10:41 AM
DiamondWhite
24
May 7, 2005 01:22 PM
