*PRODUCT RELEASE* Buschur Racing Spec Evo X JE Pistons
*BUSCHUR RACING EVO X PRODUCT RELEASE*
It took a little longer than expected to get these finished but they are finally done and instock!
What you will be purchasing is NOT your standard off the shelf JE Piston.
Teaming up with JE as we did on our other Evo pistons it has allowed us to work closely in the development of this product and get everything done to our specifications. These are ONLY available through Buschur Racing or your local Buschur Racing authorized parts distributor.
Compression Ratio: Stock (9.0:1)
Available in: Standard Bore or .20 over bore.
What you will receive with each kit is:
Pins
Retainers
JE Sure Seal Piston Rings
Complete set of 4 BR Spec JE pistons
Because these engines are so new, you would be able to use the standard bore as a direct drop in forged piston upgrade.
These pistons have also been J&E tough skirt coated. This is a special process that helps with the oiling and prevents excess wear.
Available here at the shop or online: BR Evo X JE Pistons
Pins
Retainers
Shaun@AWDMotorsports
EvoX 'For Sale' Engine Internals and Drivetrain
236
Feb 14, 2016 08:29 AM
AWD Motorsports
210
Sep 23, 2011 09:20 AM
Jrod@Buschur
Nov 19, 2010 09:44 AM
David Buschur
408
Aug 31, 2010 12:04 PM
David Buschur
10
Oct 12, 2009 04:35 PM
