Will UDP work with the turbo?
Hackish, so you suggest putting back the stock pulley? What would be the neg effect of keeping it?
Does someone with the UDP and a turbo kit please let us know his opinion?
More info guys please.
-Michael
well just run the pulley. I don't have any issues with my high compression engine which is over 300+hp. I haven't seen any issues running the RA with over 300+hp with an UDP. But also i have done the cranks for these RAs also. #1 crank pin and rod journal are out of balanced. There is a possibility of damaging the engine by running the UDP but i have yet to see it with the absence of the vibration dampener. Remember this, whenever you modify anything there is a chance of failure which is why i am sure hackish brought that up.
Crank deflection is proportional to the amount of force applied by each piston. This means the more power you make the more it will deflect the crank as each cylinder fires. This deflection is the beginning of crank harmonics. Damping these will stop the crank from "ringing". If you have the time there are many SAE articles and other engineering pieces written on the math to calculate these things.
-Michael
-Michael
It's not an issue of weight, it's an issue of vibration absorption. The stock pulley is actually a 3 piece pulley. A steel center, wrapped in dense rubber, then the outer steel part that the belt rides on. That dense rubber absorbs vibration in the crankshaft.
