Will UDP work with the turbo?
The UDP is a bad design from the beginning. It should have been the same diameter as the stock pulley, this way your lights won't dim at idle.
inertia is proportional to the mass and radius of an object turning.
I.E. a thin disk, the inertia required to spin it is I=1/2(M*R^2)
so you can free up power by lessening the mass, but much more power is freed by shortening the radius. A combination of both obviously frees the most power.
I have a turbo and I have run BOTH stock and UDP. From my personal experience I DID NOT feel any difference in power or torque. Now its a matter of engine safety....I chose safety and went with the stock pulley.
FS[Northwest]: RRM Light Weight UDP
lbwilliams44
Sep 11, 2015 12:04 PM
Darewood
Jul 29, 2010 07:05 PM
