04-06 Ralliart Aftermarket Forced Induction Tech (aftermarket turbo/supercharger related topics)
Recirc BOV to Vented BOV...
Old Jul 16, 2009 | 05:38 AM
  #31
hackish's Avatar
Originally Posted by Realistic
Well, it gives your tuner full control. More reliable.... That's enough for me. The ralliart ecu is a huge pain in the ***.
No, no and NO! Definitely not more reliable. Mitsubishi spent millions doing the ECU and tuning it. Unless you have really really deep pockets you will not get the same level of driveability. Will it start first crank? Idle as nicely? If a sensor develops a problem will the ECU tell you? No no no.
With the kit I designed I switched over to a recirculating BOV. It's difficult to do it properly as an atmospheric because many valves leak and let out an inconsistant amount of air. I am working on a system that switches to a speed density blend just after boost and a rapid decrease in TPS. This will take a lot of extra time and testing but I believe I can make it work. I'm still working hard on the reflash unit.
-Michael
SnailSpeed
Nov 25, 2016 09:52 PM
mitch44759
Lancer Aftermarket Forced Induction Tech
65
May 17, 2009 01:34 PM
slvevo8
43
Jan 18, 2009 05:47 PM
Shaun@AWDMotorsports
16
Nov 23, 2007 10:06 PM
