04-06 Ralliart Engine/Drivetrain (no forced induction)
Corner Speed, Exist Power...
Old Dec 29, 2004 | 11:18 PM
Arithmetic's Avatar
Exclamation Corner Speed, Exist Power...
Is there anyway to get more power when comming out of a corner? I always drop it into 2nd when making a turn or comming into a turn and as Im making it or finishing it, I get on the gas and its just not as fast as taking 2nd to redline in a straightline. What's the difference? I want more speed after making the turns, how do I go about this...?
Old Dec 29, 2004 | 11:38 PM
rhyzin's Avatar
the force your car is moving in is now in 2 directions so the force is distributed. you're just gonna have to make more power with traction to match. an open dif doesn't help either.
Old Dec 30, 2004 | 12:50 AM
turbonutter's Avatar
You may need to go all the way down to first to get max power going through a slow corner, but you better practice your rev matching first!
Old Dec 30, 2004 | 09:38 AM
Arithmetic's Avatar
^^^ yikes, dangerous... ill have to really slow down and rev match, jam it into first.
Old Dec 30, 2004 | 11:24 AM
Widebody Lancer's Avatar
with our cars u gotta basically doubble clutch it into 1st in the corners and it slides in gently. better diff and tires would help a lot tho
Tory
Old Dec 30, 2004 | 11:30 AM
I did say a slow corner, but yes an LSD and better tires help, I noticed a big diff just swapping tires.
Old Dec 30, 2004 | 11:31 AM
Quickshifter's Avatar
first off, what kind of turn are you talking about....
second off, i would never take a turn in 1st unless its EXTREMELY TIGHT or you have one hell of a laggy turbo.
other then that on stock turbo you should never have a problem finding power in 2nd gear on a turn....NEVER........unless you are sliding through it in neutral like a dumbass and then shifting back into gear to exit.......please dont tell me your doing this
Find the apex and put your foot on all the way on the throttle until it comepletely pushes you out then lift slightly..........thats all the help i can give you......in a nice curve/turn......you should find yourseldf exiting in at least 3rd......not 1st or 2nd
Old Dec 30, 2004 | 12:19 PM
rustyj84's Avatar
quick shifter i don't think he has a turbo, but if he does i want it. the best thing for you is the lsd (limited slip differential) and better tires. i agree not to really use first for use in the turns on less its like a 2mph turn or something. but good luck and try to rpm match
Old Dec 30, 2004 | 10:17 PM
otter's Avatar
EvoM Administrator
Take the corner faster, so you're higher in second gear, and get better tires so you don't go sliding someplace bad.
Old Dec 31, 2004 | 10:34 AM
lrh35's Avatar
just learn how to heal toe through the corner. There has been posts on how to do it in the past but all you do is put you right foot on the break and the gas at the same time so that your in controll of the turn and your keeping your rpm's high then slide your foot off of the break as you exit the turn. This takes practis and it kind of hard but you will have all of the speed and power you need.
odin
Mitsubishi TC-SST Discussion
12
Oct 26, 2013 05:14 PM
racingguy13
Aug 10, 2012 06:27 PM
Gruppe-S
Evo 'For Sale' Suspension / Brakes / Handling
Aug 3, 2012 10:17 PM
Gruppe-S
37
Jan 20, 2012 08:37 PM
Gruppe-S
66
Jul 9, 2011 12:33 PM
