04-06 Ralliart Engine/Drivetrain (no forced induction)
AEM CAI question
Old May 27, 2005 | 11:21 AM
RalliTrav05's Avatar
AEM CAI question
OK... so i know AEM makes a CAI for manual transmission ralliarts. And from what I've heard on these boards, they probably make the best one out there so far. My question is, do they have one out yet for our cars that comes with a bypass valve? I need to knwo this b/c i want an AEM intake but i get tons of rain here in Illinois and def need the bypass valve. If so, where can i get this?? Thanks
Old May 27, 2005 | 11:25 AM
Dre 8472's Avatar
I bought the Injen CAI (have yet to install it), but still bought the 2.75" AEM Bypass valve. I know that others on here also have the Injen with the bypass valve. As for brands, be it Injen, AEM or RRM you should see just about the same results performance wise. I did hear that the Injen was the one that made the nicest and most noticeable sound when it sucked in air, so thats what made my decision for me.
Old May 27, 2005 | 11:49 AM
how much for the AEM Bypass valve alone? I'd be interested in doing the same thing as you as Injen intakes are cheaper anyway. I'm guessing it was simple to add the aem bypass valve to the injen CAI...????
Old May 27, 2005 | 11:53 AM
Dre 8472's Avatar
The Injen CAI is awesome if you live somewhere where it gets really cold/wet. You can convert it to a SRI. The AEM Bypass valve set me back 75 CAD$ and it hooks up perfectly where the Injen intake SRI portion finishes off. Then you just need to hook up the rest of the CAI to the bypass valve and ur done. Very easy!
Old Jun 6, 2005 | 09:27 PM
rocketman's Avatar
Just wonderinf if thats the same with the AEM intake system, Im guessing it would be because the location of where you put the bypass valve
Old Jul 5, 2005 | 01:56 PM
rocketman's Avatar
bump, and can the aem cai use the bypass valve? Usally aem has it listed with the products but dosn't for the ralliart? (Is the AEM one peice or two?)
Old Jul 5, 2005 | 04:51 PM
Jasidus's Avatar
you can use a bypass valve with the AEM since AEM does make the bypass valve, and it is a 2 piece CAI. It can also be converted to a SRI.
Old Jul 5, 2005 | 05:48 PM
Ralliart@PDX's Avatar
The bypass only works when the filter is submerged i thought. I have an AEM CAI and live in the northwest and have not had any problems in the rain.
Old Jul 6, 2005 | 06:57 PM
Eclipse2Lancer's Avatar
Okay...the comment about one intake sounding better than another is BS...they are all basically the same, I don't care how big your sack is.
As for the AEM intake, yes it is 2 piece, and YES the bypass valve will work with it. The directions tell you exactly how much pipe you have to cut (yes, you have to cut some of the pipe to make it fit properly).
As for the AEM bypass fitting the Injen intake....it works. Otter has one on his Injen intake. He could tell you more about how easy/hard install was.
You can chek out pics of my AEM here: https://www.evolutionm.net/forums/sh...d.php?t=146868
Old Jul 6, 2005 | 07:33 PM
tuffguy's Avatar
What about the actual filters than come with the Injen and AEM CAIs? Are they the same size? And are they both closed off at the tip?
I ask because (if I remember correctly) on my old 3G Eclipse, they were different sizes.
Old Jul 11, 2005 | 04:47 PM
rocketman's Avatar
Hey I just picked up an injen one and trying to install it, how do you get the bumper off? I lossend 3 bolt in tire well, 2 under , and I think 4 on top
Old Jul 11, 2005 | 07:45 PM
Dre 8472's Avatar
i didn't bother taking off the front bumper. Just jacked the car up and was fine after removing the battery.
Old Jul 12, 2005 | 05:57 AM
RalliartCA's Avatar
I never removed my bumper either was actually a really easy instal with just the battery removed. Took about 20min.
Old Jul 12, 2005 | 08:33 AM
CF-Ninja's Avatar
i did mine without removing anything but the inside plastic peice. I also did not need to jack up my car. It was a tight fight though.
Old Jul 12, 2005 | 06:54 PM
rocketman's Avatar
Well I finished the CAI install and wow, it sounds almost like a turbo at some points, just 1 question tho, when I put the filter on it was very close to the front bumper. anyone else notice that?
