04-06 Ralliart Engine/Drivetrain (no forced induction)
4G69 Information/Cross References
Old Sep 1, 2015 | 06:37 AM
  #121
CrAnSwIcK's Avatar
Originally Posted by Gotham93
Getting the Evo IX Wagon would be difficult. I'd do it if one were available.
The downside is that the 69 is a 2.4L, the 63 is a 2L (I know how powerful the 2L is, but going with forced induction on a 2.4L will provide can provide more power gains than a 2L). The 69 is also a lighter block, and has a longer stroke.
The 63 is more commonly known, has more forums, mods and aftermarket parts due to its widespread use.
The IX also has the AWD (with LSD at rear), turbo/intercooler setup.
I've been researching and planning mods, add ons and accessories for the best part of 5 months. This is quite a bloody conundrum, makes me a little sad actually. I think I need a day of two of reflection.
the 4G69 block is lighter cause there's less material, the 4G63 has a closed deck. Also 2.4L pistons are harder to come by and more expensive, a 4G63 is capable of much more power right out of the box, with a stock bottom end, not to mention parts are much easier to come by, specifically pistons...the 4G69 would need to be built initially to be reliably capable of 350hp.
Also what is the primary reason for making it RWD? because the non-Evo lancer chassis are not designed to support a rear subframe, or AWD suspension...unless there's something different about the wagon...would be a lot of fabrication...I run about 300hp through a stock F5M42...FWD with LSD is not that bad, I've beat Evos in autocross, mind you that's on tarmac....on snow or gravel, AWD is trump...I'm not trying to shoot you down, I'm just prying a bit to get a feel for what your end goal is, so we can help. If you're serious about this, start a build thread...this is a sticky for cross reference.
Old Sep 1, 2015 | 06:48 AM
  #122
2006_RA's Avatar
Your research may not be for nothing, check Doncarbone's thread:
https://www.evolutionm.net/forums/pr...r-evo-9-a.html
May help you decide.
Also, JDM Lancers and Lancer wagons used to be available in 4WD up to the model before yours. I would check if the current models still have that trim level.
Old Sep 1, 2015 | 08:13 PM
  #123
Gotham93's Avatar
The 69 engine has been proven to handle 16psi in aus, RPW in Perth have a project on the engine. The internals are able to cope with a fair bit of punishment.
Also, there is this
https://www.evolutionm.net/forums/pr...xperiment.html
which is awesome, using the 69 block and the 63 head.
Granted using components that are stronger/lighter than oem.
I just like the 2.4L.
Also, this is my first car, so I'm deffs biased towards its capabilities.
I think I will try and find a ix wagon. Like you've said, performance wise, It's an easier way to get where I wanted to go with the ES CH.
Less guesswork, less work, and less cost in total.
The aim for the project was to make it as good as it could be. A Japanese limo wagon, but also able to pull its own weight around, as well as a boat perhaps, or a couple of fat dudes. I got a little carried away with performance stuff. Lets say I have a lot of free time.
Now my plans have changed. The ix Wagon would suit me perfectly. It'll be a while before I can turn the key in my driveway, but that's my new goal. Once I have it, I can go from there. Thanks for opening my eyes CrAnSwIcK.
2006_RA, that thread is awesome!
Old Sep 2, 2015 | 04:08 PM
  #124
Izerous's Avatar
Went through the 6G75 TB swap (eclipse gt) about a month ago now on my 4g69 equipped Outlander. I noted most who have done the swap did a bypass at the same time, weather here reaching -40'c some days through the winter I didn't do the by-pass. It left one hose a little on the short side. It "worked" but the stress on the hose was just asking for troubles and replaced it with one about 1-2 inches longer. Still a pretty easy part to cross-install.
Don't really notice the difference in throttle response but already being 25% under driven I wasn't sure I was going to notice it anyways.
Old Sep 2, 2015 | 09:44 PM
  #125
CrAnSwIcK's Avatar
how is the idle...you may want to consider tuning...
Old Sep 3, 2015 | 08:11 AM
  #126
Izerous's Avatar
Idle's a touch low I tried to address that after the UDP install years ago however the tuning software + license I got my hands on was built for the RAs and wasn't able to get around the differences in the ECU. Mainly it wasn't able to authenticate against the VIN the license was for.
Haven't bothered to take it to an actual tuner after that.
Old Sep 3, 2015 | 10:10 AM
  #127
CrAnSwIcK's Avatar
you purchased a license? for uvtune/fastworks?
Old Sep 3, 2015 | 10:52 AM
  #128
Izerous's Avatar
uvtune
Edit: He did work with me for a while on it and did quite a bit of back and forth but never got through to the ECU. Haven't tried with more recent versions of the software, but it is on my todo list... that list is just really long with a 2yo running around the house.
Old Sep 3, 2015 | 10:44 PM
  #129
CrAnSwIcK's Avatar
uvtune
wait till your 2yo is seven and teases his 4yo sister constantly...
if you have a valid license for uvtune, you should be able to get migrated to the Fastworks system, and try a newer version...the next build should be pretty sweet.
evolve_VIII
444
Dec 16, 2020 08:11 PM
doncarbone
Apr 21, 2020 01:15 PM
Howulikemyevo
46
Feb 9, 2018 10:45 PM
Jwhalen07
Oct 3, 2016 01:27 PM
doncarbone
157
Oct 8, 2015 01:28 PM
