04-06 Ralliart Engine/Drivetrain (no forced induction)
Aem Pulley's
Old Aug 4, 2005 | 06:37 PM
reimundo's Avatar
Aem Pulley's
I bought the aem tru-power underdrive pulley from a 00-04 eclipse which has the 2.4L 4g64 motor. some one told me that they would fit the ralliart. so i'm going to try to put it on saturday. BLKRalliart04 is going to post some picture of the pulleys , so i can know which one is the water pump pulley and how the belt goes. if this does or does not work i'll post up to let you guys know .
Old Aug 4, 2005 | 06:49 PM
BLKRalliArt04's Avatar
This is the only other pulley i could find in my manual. The other is in the first thread that joe's_evo8 made.
Old Aug 4, 2005 | 06:52 PM
reimundo's Avatar
the manual doesn't show all the pulley's at one time?
Old Aug 4, 2005 | 06:55 PM
No it doesnt.
Old Aug 4, 2005 | 10:56 PM
Myszkewicz's Avatar
I couldn't find anything, either. There IS a belt routing diagram under your hood, though.
Old Aug 5, 2005 | 08:55 AM
403RA's Avatar
There are two other pulleys. Check out the electical section of the manual for the alternator pulley. Also look at the powersteering section for the PS pump pulley.
Old Aug 5, 2005 | 09:37 AM
blk-majik's Avatar
tip with the manual: install google desktop (http://desktop.google.com/)
it will let you search local files on ur PC, including the ralliart manaul =) very useful. just serach for 'pulley' and it will bring up all manual pages referring to any pullys
Old Aug 5, 2005 | 10:15 AM
ProjectR#69's Avatar
What color did you get?? How much?? What pulleys get replaced with this kit??
Old Aug 5, 2005 | 10:31 AM
reimundo's Avatar
they are blue and the pulleys that get replaced are the altornator and the water pump. joe's under-drive crank pulley is coming next week, and i'm sure this will make a good combo! if it works.
Old Aug 5, 2005 | 11:02 AM
lucas569's Avatar
if they do fit do the joes after to see if you get a power increase....
Old Aug 5, 2005 | 12:21 PM
I am curious to see what kind of gains you will get from this mod
Old Aug 5, 2005 | 02:37 PM
LatinRA's Avatar
im positive this will work for you on the basis that those engines share the same pump and alt so i really hope this works for you..
Old Aug 5, 2005 | 03:13 PM
how much did you get them for??
Old Aug 5, 2005 | 04:52 PM
reimundo's Avatar
$100 for the AEM. $95 for the crank that joe made. i'm putting on the aem first and when the crank comes in i'll put that one to see if i made more power.
Old Aug 5, 2005 | 04:55 PM
reimundo's Avatar
do you guys want pictures ?
