04-06 Ralliart Engine/Drivetrain (no forced induction)
Clutch and LSD install
Old Oct 20, 2005 | 12:30 PM
Got Turbo?'s Avatar
I'm interested in buying both the Works stgII clutch kit and the RRM LSD. Does anyone have an approximation as to the number of hours needed for installation?
I was quoted about 15 hours for both at $82/hour CAD from a dealer here that has done one LSD before.
Does that sound resonable?
Thanks!
Old Oct 20, 2005 | 12:40 PM
Myszkewicz's Avatar
No. They're quoting what the book says for each job separately, added together. Most of the labor involved in the LSD install is removing/replacing the tranny in the car. If you do that while changing the clutch, it's already done.
I've seen nothing that would keep both of those combined from being a 6 hour job, max.
Our tranny doesn't look like it'd be very hard to pull, and once you get the tranny out, installing the LSD is pretty quick. I had a FWD DSM tranny (not quite the same, but very similar) apart a couple weekends ago, changing the 3-4 shift fork. Disassembling two busted trannies, and then reassembling one working one took less than 3 hours.
A simple clutch change can be done in less than two hours.
Old Oct 20, 2005 | 12:58 PM
Myszkewicz's Avatar
REMOVAL STEPS
1.TRANSAXLE HARNESS CLAMP
2.BACK-UP LAMP SWITCH CONNECTOR
3.VEHICLE SPEED SENSOR CONNECTOR
4.CLUTCH RELEASE CYLINDER AND CLUTCH OIL PIPE
5.SNAP PIN
6.CABLE BRACKET AND SHIFT CABLE ASSEMBLY
7.DRIVE SHAFT NUT
8.FRONT ABS SENSOR <VEHICLES WITH ABS>
9.BRAKE HOSE CLAMP
10.SELF-LOCKING NUT (STABILIZER BAR CONNECTION)
11.STABILIZER BAR CONNECTION
12.SELF-LOCKING NUT (TIE ROD END CONNECTION)
13.TIE ROD END CONNECTION
14.LOWER ARM CONNECTION
15.DRIVE SHAFT <LH>
16.CIRCLIP
17.DRIVE SHAFT <RH: 2.0L ENGINE>
18.CIRCLIP
19.DRIVE SHAFT AND INNER SHAFT ASSEMBLY <RH: 2.4L ENGINE>
20.STARTER MOTOR COUPLING BOLTS & STARTER MOTOR
21.TRANSAXLE ASSEMBLY UPPER PART COUPLING BOLTS
22.COVER
23.CENTERMEMBER ASSEMBLY
24.FRONT ROLL MOUNT STOPPER <2.4L ENGINE>
25.TRANSAXLE MOUNT ASSEMBLY
26.TRANSAXLE MOUNT STOPPER
27.TRANSAXLE MOUNT BRACKET
28.REAR ROLL MOUNT BRACKET
29.TRANSAXLE ASSEMBLY LOWER PART COUPLING BOLTS
30.TRANSAXLE ASSEMBLY
Pretty simple. Disconnect everything from the tranny, pull axles, remove bolts, drop tranny.
Old Oct 20, 2005 | 12:59 PM
Got Turbo?'s Avatar
Hmm... they told me the last LSD they did was 13 hours, and it wouldnt be more then an additional 2 for the clutch, if i do it at the same time.
Maybe i should shop around...
Old Oct 20, 2005 | 01:01 PM
Myszkewicz's Avatar
13 hours? They must have had to melt down some paper clips to make the spacers they needed, or something.
Old Oct 20, 2005 | 03:58 PM
Ralliart_on_LSD's Avatar
does the lsd do much of a difference? is it really worth the 900 dollars for it?
Old Oct 20, 2005 | 05:25 PM
reTro's Avatar
Well... you better get it done, or you'll have to take the "lsd" out of your name!
Old Oct 20, 2005 | 08:05 PM
justinhazard's Avatar
I would imagine that your car would stick to the road way better around corners. But it depends what your using your car for. Will I be getting a LSD? No. My car doesn't do auto-x or anything though
Old Oct 20, 2005 | 09:23 PM
otter's Avatar
EvoM Administrator
If you do a lot of tight, high-speed cornering, or drag race, then yeah, it's worth it. I would love to have one, but the price tag is way too steep for me.
Old Oct 21, 2005 | 08:59 AM
mojambo's Avatar
its the ultimate traction mod. Don't forget about winter traction also. But, with LSD when you smash the gas in a corner the front end pushes out, but you have TRACTION
Old Oct 21, 2005 | 09:22 AM
D' Ralliart's Avatar
What type of lsd is it? Oh by the way i get it... Ralliart on lsd meant your ride was hallucinating about having a limited slip diferential. J/k
Old Oct 21, 2005 | 04:44 PM
psychlancer's Avatar
i bought one from RRM, it is a Quaife
Old Oct 21, 2005 | 07:58 PM
lol nah the lsd in my name is the street i live on LakeSide Drive ... i got lsd in old english tattooed on my leg... gotta rep.... but lsd is a very fun thing to do
Old Nov 9, 2005 | 11:43 AM
Daddymac's Avatar
Where did you get yours installed? How much did you get billed for labour. Thanks
Old Nov 9, 2005 | 12:15 PM
r3z0nate's Avatar
Drugs are bad, mmkay!
