04-06 Ralliart Engine/Drivetrain (no forced induction)
Lightweight Flywheel
Old Dec 3, 2005 | 12:51 PM
Red Ralliart's Avatar
What does a lightweight flywheel do? Are they worth the money?
Old Dec 3, 2005 | 01:03 PM
AdamRA's Avatar
Free's up HP by removing rotational mass off the engine the same way light weight wheels and lightened crank pulley work.
If you decide to do it, the clutch should be done the same time
Old Dec 3, 2005 | 02:47 PM
r3z0nate's Avatar
Why not throw the LSD on there too
Old Dec 3, 2005 | 05:02 PM
AdamRA's Avatar
If you have that much money available you should sell your car
Old Dec 4, 2005 | 03:49 PM
DangerousDan's Avatar
Lightweight flywheel doesn't actually (imo) free up whp, just crank hp. But it does let the motor rev faster and come down faster. This makes for better throttle response and faster, safer shifting when rev mathcing.
EDIT: def do clutch and flywheel at the same time though. (and LSD, but like Adam said)
Old Dec 6, 2005 | 05:30 PM
blackhawkRA's Avatar
I like the theory of freeing up power at the crank and letting the engine rev quickly, but would this have any long-term effect on harmonics? The reason I skipped out on the crank pulley was to see if there were any long-term negative effects on harmonics and I imagine a flywheel would have a profoundly greater effect?
Old Dec 6, 2005 | 05:34 PM
LancerChicka84's Avatar
if u go with a lighten flywheel u shoudl lok at getting a transmission scrater plater incase the flywheel deciede to selfdestruct... (yea i suck at spelling) reason being i have heard of them rippign threw the motor and also into the passenger compartment... just a saftey recommendation... it is require at some tracks when u reach certain speeds and all...
thanks
Old Dec 6, 2005 | 06:52 PM
otter's Avatar
EvoM Administrator
The stock flywheel does not do any form of dampening, so no need to worry about that with an aftermarket flywheel.
As for the scatter sheild, I think that's more needed for the risk of shattering gears in the transmission, not from the flywheel blowing up.
Old Dec 17, 2005 | 04:59 PM
ralli_cros's Avatar
so with the fly wheel do the stage 1 clutch upgrade? just wanted to know why?
Old Dec 17, 2005 | 05:16 PM
AdamRA's Avatar
Cost savings....if you see how much it costs to rip a tranny apart you will see why you should tackle both at the same time.
Old Dec 20, 2005 | 04:27 AM
KillahB's Avatar
You *should* get your stock flywheel resurfaced anyways, when you pick apart your tranny, so at that stage, it would be entirely up to you.
Old Dec 20, 2005 | 08:10 AM
r3z0nate's Avatar
A lsd is was only $900.00...not a huge amount to consider when your transmission is takin apart
Old Dec 20, 2005 | 11:14 AM
OC_Ralliart's Avatar
lsd try 1200.
sharkster
Jul 10, 2018 10:13 PM
4g63Evo8
13
Aug 15, 2012 10:05 PM
ProStreetOnline
32
Aug 30, 2005 10:27 AM
evosevengsr
22
Dec 16, 2003 03:36 PM
EVO VIII Chris
Sep 16, 2003 08:04 PM
