04-06 Ralliart Engine/Drivetrain (no forced induction)
Transmission/ Shifter issue
Old Mar 22, 2006 | 09:00 PM
06thundergray's Avatar
Originally Posted by mitsutech005
it is normal, howeve i dont know if anyone here knows this but you are not supposed to drive with the stick in your hand (no pun intended). it needs to be able to vibrate and move freely, otherwise it will weat out the shifter bushings (unless you have brass bushings like i do). so DONT TOUCH THAT STICK!!! Wow i think thats the first time that i have ever told someone not to touch my stick, ill have to ask my wife.
very true and keep your dam foot off the clutch unless u r shifting all wears your tranny out quick!+clutch
Old Mar 23, 2006 | 07:39 AM
willRalliart's Avatar
Thanks for the info, did not know this. I rest my hand on the shifter all the time when my g/f is not in the car with me, which is not often...but still a lesson learned, thanks guys.
Old Mar 23, 2006 | 11:28 AM
ralliartjapracr's Avatar
Originally Posted by bigdoggy_dog
This is true. There is even a warning in your owners manual for this. But it's ok to rest it lightly on there, you just don't want to be putting a lot of weight on it. As long as you are allowing it to do its thing you can keep your hand there.
that is so true, right now my car is at the dealership getting the synchro's replaced for 1st and 2nd as well as 3rd and 4th. Thank god for my power train warranty!
Old Mar 23, 2006 | 01:54 PM
MitsuSkot's Avatar
I have 80 shore filled front and rear motor mounts, as well as brass shifter base and under-hood bushings. There is no movement of the shifter. Well maybe if you bring out the micrometer there is, but you definately can't see/feel it.
Old Mar 23, 2006 | 11:12 PM
bigdoggy_dog's Avatar
I have just the base and under-hood brass bushings. I can notice slight movement, but I really don't rest more than a finger on the shifter when I'm driving.
