RRM Catback Exhaust?
^^^ +1.
and don't bother modifying it, nothing against you're friend but you'll be more likely to have problems later on with the exhaust that way. Seems like alot of people are backing this set up. I'd just go with it.
Originally Posted by bruce988jl
Alright well if that's said.. but won't the metal clamps cause the metal piping itself to compress which would make it harder to remove and reinstall?
Also you should have no real need to remove the exhaust anyways so it sounds like your making a mess out of nothing. Go install it already!
I would.. but i have to strip all my aftermarket parts out of my car... My throwout bearing is going awol and there's a crazy clicking sound coming from my tranny so i'm due to go back to the dealer. And since its transmission problems this time i'ma play it safe and just return the car to stock. Although after all this ish is done i will have everything installed..
Its becoming quite discouraging to see so many post contain the words TRANNY PROBLEMS, ive seen a few other threads where this was said and im starting to wonder if i should be nervous.
Good luck with the dealer though....let us know how it goes.
Originally Posted by Joe's_EVO8
Either way I am not concerned because it is a 2.25" DP. The most important part of the exhaust flow is the headers and DP, after that the exhaust air has cooled down and expanded and the 2.5" may not be so bad.
EDIT: im referring to the original DP not the new header/downpipe combo.
Where did you measure this 2" I assume where it bolts to the CB?
The only reason I checked is because I was having the high-flow cat installed, i bet no one else even checks, just get a new toy and bolt it on.
Originally Posted by pocoRA
Ya, I measured the opening, which was slightly under 2". Not sure where the exhaust shop measured it but they confirmed it was 2"
ROAD/RACE
