Piggyback Maps
Answer received, thanks RRM!
edit - that awkward moment when you read over an old thread and spot a typo in your post...
You will need something for controlling timing and fuel, and something that is different then the NA piggyback. Currently you can look into this or wait a little while longer for the Hackish software to hit the market - could always inquire with him about a tune/reflash.
You will want one of our turbo Piggybacks. We have them for each specific car/ year. This is important to remember. That said call us for more info so we can set you up with the right one. These control timing and also have a built in MAP sensor. They read boost. Lastly like all of our piggys, they come pretuned- basemapped. Call us to talk about turbo options. Some guy are better suited for a kit than trying to piece one together and learn turboing on their own engine. It is a pricey way to learn. Lets talk. Call and ask for me, Rob, when you are ready.
ROAD/RACE
ROAD/RACE
hello
I have a question it is not about a map. It is about my RRM piggyback. I put my piggyback in and I have 2 new o2 sensors and once the RRM piggyback is in I get a code saying that I have low votage to my o2 sensor sometime its the down stream and sometimes up and once in a awhile ill get both. once the code comes the car runs a little better but before it doesn't run right. any ideas can someone please help me out
Would anybody suggest a map to me that is already posted on here? My N/A setup is as follows:
Injen SRI, Custom Down Pipe, High Flow Cat, Custom Exhaust, Stage 2 clutch, Fidanza Flywheel, RRM Underdrive Pulley, 65MM throttle body. The RRM map works well but I'm guessing I can get better power from somebody elses map. Please let me know any suggestions.
not sure if the 2004's can be OBD2 flashed yet...even if you need to send it in, it's only the initial reflash it needs to be sent in for...
email hackish@gmail.com, or go to support.fastworks.com
Or you can get ahold of OttRalliart the MMC/ECU flash method works on the 04 models. And he was doing a lend a tool thing last time I talked to him so you wouldnt need to actually purchase MMC flash or the Tactrix cable.
