04-06 Ralliart Engine/Drivetrain (no forced induction)
Check englight codes PLZ HELP
Old Jan 3, 2007 | 09:35 AM
MyRoN's Avatar
So guys i got my master cylinder put in and everythign looks and feels fine.
So my service engine soon light came on. SO i checked the codes and here are
PO113-IAT sensor 1 circuit high input
PO300-random /multiple cylinder misfire detected,
So now i have to figure this...So the best help ever is HERE..so let me know guys...what ya think.
Myron
Old Jan 3, 2007 | 09:45 AM
Myszkewicz's Avatar
Is your MAS plugged in? Both of those codes mention the Mass Air Sensor, and you probably unplugged it and removed the intake plumbing to put in your master cylinder.
Old Jan 3, 2007 | 10:00 AM
MyRoN's Avatar
I put everything back together but i will check..i have an SRI. and just took off the Filter..so i will have to recheck everything...........thats all?
Old Jan 3, 2007 | 11:19 AM
Myszkewicz's Avatar
Try unplugging and replugging your MAS, then. Double-check the hose clamps on your SRI, too. Then reset the ECU or use a scanner to clear the codes and see if they come back.
Old Jan 6, 2007 | 01:31 PM
KreepaEvoX's Avatar
Its pretty common that the cause is a bad connection to the MAF, also, the MAF not sealing properly and the one that happened to me was that thye MAF was a bit dirty... This one you can correct with ELECTRONICS CLEANER, comes in a spray can. You just take the MAF out again, disconnecting it first then spraying it OUTSIDE the
enbgine bay
MyRoN
Jan 2, 2007 04:00 PM
MyRoN
04-06 Lancer Ralliart How To Requests / Questions / Tips
Dec 29, 2006 10:02 AM
MyRoN
Dec 23, 2006 06:23 PM
MyRoN
Apr 19, 2006 07:22 AM
