04-06 Ralliart Engine/Drivetrain (no forced induction)
CAI induced ECL
Old Jun 24, 2007 | 01:51 AM
Silverfox742's Avatar
CAI induced CEL
A frustrating one this. My ECL absolutely refuses to shut off after the install of the RRM CAI. I've had it repeatedly checked over, there are no leaks whatsoever, filter is fine, and all scans indiciate normal operation. All mechanics I have spoken too are mostly baffled. Anyone else encountered this issue?
Old Jun 24, 2007 | 02:16 AM
migueralliart's Avatar
Try resetting the ECU and driving it slowly for about 40 miles sometimes helps..!!
Old Jun 24, 2007 | 04:10 AM
MITVRX's Avatar
^ I agree.
1. As migue mentioned
2. Reset the ecu and drive for a long while, perhaps it needs time to shut off.
3. Make sure the pod filter is on secure.
4. Make sure the MAF sensor is secured down.
5. No leaks (as you have already done)
Old Jun 24, 2007 | 05:49 AM
drewbad's Avatar
Do you mean ECL = check engine light?
If so.. I've beentroubleshooting for months:
https://www.evolutionm.net/forums/sh...d.php?t=278222
Are you getting the P0171? You said all scans indicate normal operation, so maybe ECL doesnt mean the check enginelight?
Old Jun 24, 2007 | 03:03 PM
I'll try resetting the ECU and yes, I did intend for it to mean CEL my bad. And PS, as a new member I find you all tremendously helpful, thanks a lot! Cheers
Old Jun 24, 2007 | 05:06 PM
AdamRA's Avatar
double check everything it's possible that unmetered air is getting in. (just a guess)
Old Jun 25, 2007 | 04:35 PM
akinakin's Avatar
Did you re-install the MAF Sensor backwards ? is it pointing in the right direction ?
(not sarcasm....a serious question )
Allan
Old Jun 25, 2007 | 10:31 PM
akira2_03's Avatar
Allan
yes first check to make sure u installed the maf sensor in the right direction then disconnect ur battery for 5min then connect it back up. (this resets ur ecu) then it should work perfectly!
