04-06 Ralliart Engine/Drivetrain (no forced induction)
cold air question
Old Jul 4, 2007 | 07:16 PM
turtle725's Avatar
cold air question
i just installed my rrm cold intake and i sounds amazing and is awsome. but i noticed that my idle is messed up. it keeps on bouncing around 500 rpm . before the cold air it was very smooth..
i think it is because the car can not get enough air fast enough through the cai so it has a bad idle.
can anyone tellmy when this is happeing and if i can fix it.
thank you
Old Jul 4, 2007 | 07:31 PM
otter's Avatar
EvoM Administrator
Your ECU needs some time to adjust to the new airflow. The car is getting more air than it's used to. Give it some time and the ECU will figure it out. If you're impatient, you can disconnect your battery for 10 minutes to reset your ECU, and let your car relearn from scratch.
Old Jul 4, 2007 | 07:42 PM
PR_Mivec's Avatar
Idle
Old Jul 5, 2007 | 05:35 PM
Joyrider's Avatar
Yep let it idle for 10-15 minutes after resetting your ECU.
Old Jul 6, 2007 | 09:46 AM
turtle725's Avatar
i did that and it helped out alot but my idle is still not like it was. and also my check engine light keeps on coming online after 100 miles.
Old Jul 6, 2007 | 10:00 AM
migueralliart's Avatar
Could you please verify that the hose that comes from the valve cover is attached ?
And also verify all the clamps are adjusted?
Old Jul 6, 2007 | 11:29 AM
Optimus's Avatar
ralliart's don't have the hose from the valve cover... at least mine doesn't.
Only the 02-03's did... and I believe that was a vacuum line
my idle does the same thing after I reset the ECU... sounds horrible for that first like 5 min or so.
Sounds like the SRI's and the CAI's have the same problem with throwing the CEL...
Old Jul 6, 2007 | 11:37 AM
Your ralliart is a special one then.
As a matter of fact it does , look at the picture its just past the MAF, if he failed to install this hose it WILL give idle problems
Old Jul 6, 2007 | 01:06 PM
turtle725's Avatar
i do not have a hose. . . .or even a place on the cai where the hose would be placed .. i have a 04 ralliart
Old Jul 6, 2007 | 01:32 PM
DangerousDan's Avatar
you are saying your valve cover has no hose attached to the vent on the forward right corner(nearest the battery) of the valve cover, or that there is no vent at all?
Old Jul 6, 2007 | 01:33 PM
if you don't have this hose and the vent is not plugged this is causing your problem.
edit: to clarify, unmetered air is getting into the engine.
Old Jul 6, 2007 | 03:11 PM
turtle725's Avatar
yes i dont have a vent you can even see it one the pic from rrm you can not see a vent on it
Old Jul 6, 2007 | 04:08 PM
That would explain , did you check the clamps ??
Old Jul 6, 2007 | 04:45 PM
turtle725's Avatar
i tightened everything very good when i initally installed it .. .but tomorrow i am gonna take it apart again and try to make sure there are no air leaks
Old Jul 6, 2007 | 05:22 PM
kkaos47's Avatar
correct me if im wrong with the rrm cai dont u have to use the stock 90degee tubing n that is where u have u line coming from ur valve cover?????
