04-06 Ralliart Engine/Drivetrain (no forced induction)
installed rrm header an dp
Old Aug 7, 2007 | 01:15 PM
xfreakx's Avatar
yes i installed header an dp with hf cat an magnaflow resinator an muffler everything sounds an runs great just it keeps throwing code for running to lean an for the cat is there anything i can i do to stop it from throwing the engine light??
Old Aug 7, 2007 | 01:37 PM
otter's Avatar
EvoM Administrator
Reset your ECU, first. That should take care of the lean code. As for the cat light, was the cat installed before or after the second O2 sensor?
Old Aug 7, 2007 | 01:41 PM
xfreakx's Avatar
ya i reset the ecu an it was off for about 60 miles then popped on again. the 02 sensors is installed like the stock one before the cat an after the cat
Old Aug 7, 2007 | 01:43 PM
otter's Avatar
EvoM Administrator
Chances are that the highflow isn't working as well as the stock cat did. You might have to throw an antifouler or two on there to get rid of the light.
Old Aug 7, 2007 | 01:47 PM
xfreakx's Avatar
whats a anti fouler
Old Aug 7, 2007 | 02:18 PM
bruce988jl's Avatar
google it..
basically tricks the engine into thinking the cat is fine.. i think..
Old Aug 8, 2007 | 02:06 AM
reTro's Avatar
Got any picz? I'm seriously considering putting a cat back in line too.
Old Aug 8, 2007 | 07:30 AM
otter's Avatar
EvoM Administrator
https://www.evolutionm.net/forums/sh...ad.php?t=98573
It's hit and miss for some people, but it's cheap enough and easy to do where it's worth a shot.
Old Aug 8, 2007 | 07:16 PM
KreepaEvoX's Avatar
The one I had before didnt work good, but the one taht the header brought, solved it for me
Old Aug 13, 2007 | 09:44 AM
migs647's Avatar
RRM (roadracemotorsports) sells one, It's more expensive than the 1 or 2 anti-fouler trick, but it's ready to be installed with no drilling necessary.
Basically your first O2 sensor reads what the exhaust contents are BEFORE THE CAT and the second O2 sensor reads what the exhaust contents are AFTER THE CAT, it then compares them making sure your cat is doing it's job. If the contents are too similar it throws a code. By installing the anti-foulers, it moves the O2 sensor further away from the exhaust, thus reducing the contents being read.
Old Aug 15, 2007 | 05:34 AM
byc_panty's Avatar
hey so what are your reviews in terms of performance?
Old Aug 15, 2007 | 09:23 AM
ixhavexfaithx's Avatar
video?
Old Aug 31, 2007 | 12:20 PM
custom ralliart's Avatar
Re-tune the map. It worked for me.
Old Aug 31, 2007 | 12:58 PM
DangerousDan's Avatar
+1000000000000000000000000000000000000000000000000 00
I can't even say this enough. If you mod the car and it throws a CEL it's because you haven't adjusted your fuel. if you have no way of adjusting your fuel, you can't get rid of the CEL. you can't just go changing stuff on the car and expect the ECU to compensate all by itself.
retuning your fuel may get rid of your 420 code too, because the cat works best at a certain AFR and the richer the better.
Old Aug 31, 2007 | 01:45 PM
migs647's Avatar
So you're basically saying that just about any breathable mod (maybe sans CAI and exhaust) will require a PB to do it right? I guess the PB just moved up a few places on my list.
(100th post... i am evolving now )
BABYEVO1
55
May 9, 2014 08:18 PM
rallyme
Lancer Engine Tech
Feb 27, 2005 04:44 PM
SEVEN
Jul 21, 2004 02:47 PM
simevo
Apr 12, 2004 10:12 PM
Nero
Lancer Engine Tech
10
Dec 16, 2003 09:15 PM
