04-06 Ralliart Engine/Drivetrain (no forced induction)
transmision...
Old Oct 29, 2007 | 04:38 PM
kulka's Avatar
transmision...
Hello there,
I am new here but i watch this forum for around two months now.
So here is my problem... I bought 04 Ralliart 4 months ago. I have some problem with "synchronization?" lol... all the time when i want to put 1st gear while car is rolling i cant (don't say im going too fast because even when i am going 10mph i cant..). i mean i can but i have to stop the car almost completely. I wasn't yet at any shop or anything because first i wanna get some knowledge... I don't know if i put it in a way you can understand me... i am sorry English is not my first language...
if anything i will try to explain it more clearly... thanks!
Old Oct 29, 2007 | 07:11 PM
LithiumX's Avatar
i get the first gear lock out at low speed too its been there since day1. i just thought it was the saftey lock out i just use 2nd whenever it happend.
Old Oct 29, 2007 | 07:28 PM
otter's Avatar
EvoM Administrator
It's likely normal. First gear isn't easy to get into unless the car is near stopped, and you really shouldn't need to get into first gear unless going from a stop.
Old Oct 29, 2007 | 09:22 PM
kulka's Avatar
i know i should use 1st gear only when i am at a stop but its annoying that sometimes even when i am at a stop and try to put 1st gear on i cant put it and sometimes i have that sound when u miss a gear/depress the clutch and try to put a gear (that weird sound) lol :/
and i forget to tell u guys that i have the same problem sometimes when i try to put 5th gear while on a high speed... I have no idea what is going on...
Old Oct 29, 2007 | 10:29 PM
migs647's Avatar
How many miles are on your car? You could be due for a new throwout bearing or new clutch? 5th is a little tough to get into quickly... there is a little more pressure on 5th than other gears for some reason. It is normal.
But yah, sounds like your 1st is normal. I wouldn't worry about it unless you're grinding trying to put it in when you are at a stop. I usually lug mine a bit in 2nd to avoid going to 1st because it's so torquey.
Old Oct 29, 2007 | 11:26 PM
GearDownSon's Avatar
Its normal dude.
i would change the tranny fluid just as a precaution.
Old Oct 30, 2007 | 05:42 AM
kulka's Avatar
my car has 40,000miles...
Old Oct 30, 2007 | 07:41 AM
bruce988jl's Avatar
Its normal, I have a new clutch, fluid, bearing etc... I have some problems throwing into first at a roll just creeping out of my driveway. I normally just jump to 2nd. I don't mind rolling in first, just not worth the effort to fight it to get in.
Old Oct 30, 2007 | 08:04 AM
kulka's Avatar
Same here i just give up puting it to 1st and just try to go with 2nd..
but the 5th gear is weird :/
Old Oct 30, 2007 | 08:37 AM
DangerousDan's Avatar
unless I am at a stop the car pulls fine in 2nd. also, it starts out in second pretty easily. rev match if you want to shift into first while moving... like buttah
synchros could be wearing, change your fluid like GDS said. go with something decent.
don't start a thread about which tranny fluid either there are already a few that will answer ALL of your questions. even if it doesn't, bump the one that is closest with your questions.
Old Oct 30, 2007 | 02:47 PM
bruce988jl's Avatar
Yea gotta make sure to rev match when you're going into first or you'll experience the most unpleasant jolt...
Old Oct 30, 2007 | 04:55 PM
LithiumX's Avatar
yea forgot to say try double clutching and rev matching , dont try to force it or you will be treated to the sickening sound
dbl clutching really helps
Old Oct 30, 2007 | 05:03 PM
migs647's Avatar
Lol... now dan has to warn on various topics... gotta admit... the 40 different transmission fluid threads was getting a little ridiculous.
Old Oct 30, 2007 | 05:09 PM
evo L's Avatar
Originally Posted by kulka
Hello there,
i fail to see a problem here, most cars wont let you go into 1st, even at 10mph... i kinda start to slow down and hold it at first until the trans takes it.
Old Oct 30, 2007 | 10:20 PM
kulka's Avatar
yes i do do double clutching or rev a bit especially while engine breaking
anyways thanks guys for your help.
