04-06 Ralliart Engine/Drivetrain (no forced induction)
CEL - Affecting performance?
Old Nov 20, 2007 | 08:17 PM
MITVRX's Avatar
Lightbulb CEL - Affecting performance?
Hey Fellas,
You know how most of us guys have the CEL show up once we have our headers installed, well some of us put the CEL eliminator and some of us don't right ..
I was wondering, though "technically" nothing is wrong with the car when the CEL displays, could this affect a tune? Because from what I gather, wouldn't the ECU go into 'safe-guard' mode and not allow the ecu to perform to its full ability restricting timing, ignition etc.
I just figure the ECU is being told something is wrong and therefore go into safe-mode, undermining the car's ability.
Discuss please
Old Nov 20, 2007 | 09:14 PM
otter's Avatar
EvoM Administrator
A CEL from cat inefficiency doesn't change anything, it's merely there as required by law to notify you that your catalytic converter isn't working at full efficiency. All the important work is handled by the first O2 sensor. If your car were in limp mode, you'd know it. You would have no power and wouldn't be able to rev above 3k.
Old Nov 20, 2007 | 09:32 PM
MITVRX's Avatar
Thanks for that otter, so the CEL is coming from the second o2 sensor and this merely has no affect on the car's ecu other than letting the driver know that there is a cat inefficiency. Am I right in saying that?
Old Nov 21, 2007 | 04:52 AM
DangerousDan's Avatar
it will go back to the default fuel trims, if I am not mistaken. still little to no affect, as your fuel trims have only changed due to the tune on your piggyback anyway. well, unless you didn't reset the ECU before tuning the piggyback(kind of dumb to install it with the battery hooked up though)
Old Nov 21, 2007 | 04:40 PM
PR_Mivec's Avatar
i have a cel from "poor egr flow" and it does not affect me any bit
Old Nov 21, 2007 | 05:47 PM
KreepaEvoX's Avatar
lol, trukero
Old Nov 21, 2007 | 06:17 PM
$MIVEC$'s Avatar
just make it no flow at all.... no ah prendio CEL por ahora
Old Nov 21, 2007 | 07:21 PM
PR_Mivec's Avatar
wise asses
Old Nov 22, 2007 | 07:01 AM
well, I can't tell if you are playing on teh OT games or being serious the MAP sensor checks the EGR valve though, that much I have come across in my research.
Old Nov 22, 2007 | 07:35 AM
PR_Mivec's Avatar
no games is a real set of codes thats bugging me
P0401/403/404
EGR flow - insufficient, circuit malfunction, undetected range
(remember i dont have an egr, plan to put it back when i boost it up)
and again, no effect on performance
this codes are usual if and when you eliminate totally the egr, i didnt blocked it, i eliminated it
Old Nov 22, 2007 | 09:13 AM
so there is no circuit, that explains the codes for sure
I guess it's not really bugging you then I wouldn't expect a decline in performance from the EGR circuit, the MAP circuit doesn't put it in limp mode either.
which gives me an idea...
Old Nov 22, 2007 | 11:57 AM
Mystic_Korean's Avatar
Are u sure about this? I thought the ECU would put the car into a "safe mode" untill the CEL is fixed. I'm asking because I have a header and the CEL only goes off once a month and I can tell the difference in power... maybe it's just in my head =/
Old Nov 22, 2007 | 12:59 PM
MITVRX's Avatar
Yeah thats what I thought, but apparently the second o2 sensor does not affect the ecu. The first one does.
Mine is constantly on, so I'm going to speak to a tuner relating this and have some AF pulled up on the dyno!
Old Nov 24, 2007 | 09:02 PM
SSP-Ralliart's Avatar
All that will happen is that the car will recieve alot more air therefore causing it richin up. Your ECU will go into default mode with cat code do to wrong reading from O2.
Old Nov 24, 2007 | 09:05 PM
If you have a scan tool or computer to hook up to the car you can monitor both Fuel trim 1 and fuel trim 2 which should be Forward and rear o2. If you have a scanner for Mitsu. then it should read Ox. Sen.1 Ox. Sen.2 etc. Both send info to ECU. I would check it and also do have the spacer for rear o2?
