04-06 Ralliart Engine/Drivetrain (no forced induction)
Ported Intake Mani Issues
Old Mar 10, 2008 | 05:02 PM
KreepaEvoX's Avatar
Ok, dudes see if u guys can help a friend. He installed a ported IM, some shop did it for him. the issue is when he started it at first, the car was kinda weak turning the engine( starting) he started driving it, not flooring it, but letting the car climb rpms, all normal.... he gets to a stoplight, the car just dies, no signs of nothing, just shuts down like if he turned the ignition off. The car wouldnt start after that, so he took it back to the shop, removed the spark plugs to run a leakdown test.... they notice the sparks are burning lean, theyall had white residue instead of dark and it has tiny metal particles attached ( maybe from a faulty IM cleanup after porting), the thing is that every piston gave back 90 psi from the test, when mostly its supossed to run to 180/200 psi
Any tip from the guys that have IM?
Old Mar 10, 2008 | 08:01 PM
egk-69's Avatar
that doesnt sound too good!!!
Old Mar 10, 2008 | 08:23 PM
otter's Avatar
EvoM Administrator
Just a shot in the dark, but I'd worry that they didn't clean the manifold before installing it. If metal bits got in they could've chewed up all kinds of things. Valve seats come to mind. But it's very, very strange that every cylinder came back at 90. Hard to imagine a situation where every cylinder would drop identically.
Leakdown test should've helped identify the leak, though, unless you mean that they only did a compression test.
Old Mar 10, 2008 | 08:54 PM
SSP-Ralliart's Avatar
So was it a leakdown or compression test? I would try and compression test dry first then do a wet compression test....it should bump up the compression....also...a running compression test....this will tell you if you have a bad valve seat, leaking valve, bad head gasket, rings, etc..... There is still alot of test to do until you narrow it down....
Old Mar 10, 2008 | 08:57 PM
otter's Avatar
EvoM Administrator
^agreed.
Old Mar 11, 2008 | 04:30 AM
KreepaEvoX's Avatar
My bad, compression test, got mixed up with the terms. The were gonna pull the head today, lets see where that takes us......
I didnt even think about the valve seals, thanx, lets hope he reads this before heading out
Any other suggestion is welcome.
Old Mar 11, 2008 | 06:43 AM
PR_Mivec's Avatar
i was dumbfounded when Genno called me, my bet is that they (at the shop) didnt clean the manifold too well before handing it to him... let see what today brings to him......
Old Mar 11, 2008 | 06:51 AM
otter's Avatar
EvoM Administrator
Do a leakdown test and wet compression test before you pull the head. That way, before you pull the head, you'll know what's leaking before you pull everything apart.
Old Mar 11, 2008 | 07:00 PM
PR_Mivec's Avatar
on all 4 pistons the compression ring failed and it seized the engine, so far no damage to the head or block, genno was luck he wasn't banging' on the car.. it could have been worst...
how did this happen.. another chapter of unsolved mysteries
Old Mar 11, 2008 | 07:41 PM
Black Rally's Avatar
that's correct hopefully no damage to the pistons, cylinders or rods
the most incredible part is the car was working with no problems, no check engine, no stranger sounds and the temp was OK all the time
Old Mar 11, 2008 | 08:17 PM
KreepaEvoX's Avatar
Then U got that RA from the same LEMON batch i got mine, LOL
Old Mar 11, 2008 | 08:24 PM
[off topic]
i was thinking.... the head is out so why don't send it to the machine shop
[end/off topic]
the piston rings are very expensive in Puerto Rico, some one here can help me with the price!!!!!!!!!!!!!!!
Old Mar 11, 2008 | 08:27 PM
KreepaEvoX's Avatar
Originally Posted by Black Rally
[off topic]
[end/off topic]
Prolly you'll get metal shears in your block too, leave it alone lol
Old Mar 11, 2008 | 08:49 PM
otter's Avatar
EvoM Administrator
Wow, all 4 at once? That's very strange. Great time to upgrade internals.
Old Mar 11, 2008 | 09:00 PM
yes, today all ready I was talking with a friend to get some custom CP Pistons with EVO 8 or Pauter Rods
