04-06 Ralliart Engine/Drivetrain (no forced induction)
Ported throttle body discussion
Old Sep 8, 2008 | 05:09 PM
  #61
ralliart610's Avatar
so if this is a direct swap without porting i found the next thing to buy
Old Sep 9, 2008 | 07:52 AM
  #62
Fifty's Avatar
Originally Posted by Ralli04
ive been talking to some guys over on the club4g.org forum and this is what we discussed...here
im confused then, why was there all the talk of "needing" to port the IM's inlet side to match? when yours is on there without the IM ported and its working fine...
Wow club4g got a new look, it hurts my eyes to read the reversed type
Needing is the wrong word, its not needed to port the IM's inlet to get the throttle body to work. It will work regardless. HOWEVER, you should do it cause the IM's inlet is now smaller then the throttle body so without porting it, it will cause a restriction in airflow. Regardless it's an easy job and you can do it yourself.
Couple of points though, when you buy you new TB make sure it comes with the TPS. If you try and swap the Ralliart's TPS onto the TB it will not work. You need the 3.8l TB and TPS. Also if you search ebay for PAM's Auto they have 3.8l throttle bodies for roughly $130 and if you offer something lower like $110 he will normally go for it.
Old Sep 9, 2008 | 09:06 AM
  #63
egk-69's Avatar
I've said that like 70 times in this forums, I think I even said it on this thread
the TB will bolt on the intake manfifold, but you will have 5mm restriction cause the intakemanifold inlet its 60mm and the TB its 65mm, its simple to understand. Im even surprise the TB opens, i mean, 5mm its a lot the throttle plate can get stuck in there...
Old Sep 9, 2008 | 09:54 AM
  #64
Fifty's Avatar
I think people were just getting stuck on the word "needing" thinking that without it, it wouldn't work.
Old Sep 9, 2008 | 03:46 PM
  #65
Ralli04's Avatar
i searched for pam's auto and i didnt find anything...or any eclipse 3.8L TB's on ebay
Old Oct 4, 2008 | 11:09 AM
  #66
omgivec's Avatar
no results yet, anyone?
Old Oct 5, 2008 | 06:52 AM
  #67
Fifty's Avatar
This is the seller: mini-genie, he has two stores Pam's Auto and Deep Discount Car Parts. Also quick google search brings up:http://www.pamsauto.com/
What results are you looking for?
Old Oct 6, 2008 | 05:08 PM
  #68
omgivec's Avatar
gain's with the throttel and manifold anyone with that setup installed?
Old Feb 8, 2009 | 04:29 PM
  #69
Ralliart_on_LSD's Avatar
i just found this and have to bump it
what the hell
the 3.8 liter eclipse throttle body fits our car? wtf how come i never knew this????
I'm buying one tomarow
what exactly needs to be done to get this to fit? just bolt it up and good to go? or what?
and after a few months with it on, is it still relaible?
Old Feb 8, 2009 | 04:37 PM
  #70
toortool's Avatar
Fifty has it on!
Old Feb 8, 2009 | 08:32 PM
  #71
fiddy cent?
Old Feb 8, 2009 | 08:36 PM
  #72
fifty get back here, i have many queststion to ask you.
Old Feb 9, 2009 | 09:19 AM
  #73
Fifty's Avatar
^ I have a pm
What do you need sir?
Old Feb 9, 2009 | 09:30 AM
  #74
So what did u do to get the 3.8L throttle body to fit? is it a basic bolt on? It don't throw the car in limp mode and run horrible? bassically what did you do to get it to work? Cuz i always thought it wwont happen. thanks so much
Old Feb 9, 2009 | 09:36 AM
  #75
HondaHunter78's Avatar
tortool do you have yours on yet
