04-06 Ralliart Engine/Drivetrain (no forced induction)
How to port intake manifold
Old Jul 9, 2008 | 11:50 AM
omgivec's Avatar
Want to port myintake manifold, how much do i need to port? whats the specific diameter?
Old Jul 9, 2008 | 12:01 PM
PR_Mivec's Avatar
as big as the gasket hole.. any bigger you will ruin the head
the exhaust port is a tad different... you can add 2mm yet you will need to polish the hell out of that side.. mirror like to give an example....
Old Jul 9, 2008 | 09:35 PM
omgivec's Avatar
thanks bro. looking foward to do it
Old Jul 10, 2008 | 05:26 AM
evo323's Avatar
You should polish the exhaust very well and a bit the intake. There are different theories about it but I would still polish it slightly to increase air flow. And don't go larger than the gaskets.
Old Jul 10, 2008 | 08:08 PM
egk-69's Avatar
Yep, what PR MIVEC said, go as big as the gasket, but make sure you dont go bigger than the head ports, or you will create a... (ESCALON) and that will ruin the flow. You can also port the throttle side of the intake manifold, and add a Eclipse 3.8L throttle body (5mm bigger than the Ralliart) and its PLUG & PLAY
Old Jul 14, 2008 | 01:33 PM
omgivec's Avatar
thank guys that will be my next mod.
Old Jul 14, 2008 | 02:27 PM
egk-69's Avatar
did I mention anywhere on EVOm that im selling a 3.8L Eclipse throttle??
hehehehe
Goodluck man
Old Jul 23, 2008 | 06:48 PM
Thrice's Avatar
I know it could sounds like an newbie question,but...
I want to port/polish my intake manifold too.
I know i Have to grind not much than the gasket.
My question is
How long in the hole i have to grind ? ( the arrow on the left on the picture)
Do I need to grind something else than the fours cylinder tube ? I know i can do the Tb too, but i won't touch to that... Will I feel gain if I only do the four tube ?
Thanks
Old Jul 23, 2008 | 07:00 PM
Realistic's Avatar
for the exhaust header, a ceramic coat works well
Old Jul 23, 2008 | 07:14 PM
DangerousDan's Avatar
as far as you can reach and still keep it nice and smooth. you don't want any jagged edges, so don't worry too much about it. making that transition into the head smooth is important, so don't make the holes bigger than the gasket unless you are porting the head too(and getting a bigger gasket)
My question is
Thanks
Old Jul 24, 2008 | 06:43 PM
Thrice's Avatar
Thanks Dan, I'll do the job as soon as I get time to do it. I'll post pic for sure...
Old Jul 24, 2008 | 07:06 PM
MitsuJoe's Avatar
You do NOT want to polish it. Intake air flows the best through a rough surface to go into the head.
Old Jul 25, 2008 | 03:34 AM
Thrice's Avatar
HUmm, from what I thought, air flow is better when the surface is smooth... no ? So i've to port the IM but do I need to polish it a lot to make it smooth? just a little bit to let it a little rough or just let it rough completly (erase big marks that all) ?
Old Jul 25, 2008 | 04:18 AM
MitsuJoe's Avatar
You want there to be a slightly rough surface to it. Similar to say a 200 grit sand paper as an idea.
Old Jul 25, 2008 | 08:36 AM
+1, polish is for exhaust side. my remark was to keep you away from gouging the runner all to hell. hopefully no one confused smooth with polished, but if you did there is a big difference.
