04-06 Ralliart Engine/Drivetrain (no forced induction)
New Eclipse ECU
Old Feb 2, 2009 | 08:27 PM
BABYEVO1's Avatar
New Eclipse ECU
hey guys if this has been asked before i apologize. but since the Eclipse has the 4G69 like the RA wouldnt the ECU be able to work on the RA i have a feeling that it wont but im just askin
Old Feb 3, 2009 | 09:08 AM
Black Rally's Avatar
well if the eclipse ECU can be used ont he RA we can use the AEM FI/C without any problem...
but our cars are OBD II and the eclipse is CAN BUS, if some body can bring more info about the difference between CAN BUS and OBD II and possibilities to convert from OBD II to CAN BUS
Old Feb 3, 2009 | 10:17 AM
BABYEVO1's Avatar
it would be nice if there was a way to convert to Canbus cause correct me if im wrong but doesnt the Eclipse ECU already come with the turbo map????? or it has a map sensor not a maf something like that please correct me
Old Feb 3, 2009 | 12:34 PM
RalliDew's Avatar
assuming the wireing harness was the same the ecu canbuss or obd2 im not sure would matter jsut aslong as the engine sensors are all the same to the T the ECU is ment for running the engine so if it were all the same i think it would run the car no problem other than maby the load differences but if the 4g ecu is sensitive like the RA's i would say it might be rough
Old Feb 3, 2009 | 01:30 PM
I already check and the harness is not the same one, but i think that the engine sensor are the same
Old Feb 4, 2009 | 10:52 PM
hackish's Avatar
Yes, in theory you could use it but in practise it would require swapping out many electrical bits, including the cluster. Not worth the cost/expense.
-Michael
Old Feb 5, 2009 | 05:05 AM
-Michael
maybe not too expensive like a re-flash
Old Feb 5, 2009 | 08:41 AM
hackish's Avatar
Have a look at the price of a complete harness, plus the dash units, cluster and anything else that talks to the CAN bus, for example the anti-theft. After you spend a grand in parts you should have about 30-40h of work removing the dash and adapting the thing to work. Even so you're not 100% guaranteed it will work.
The alternative - $500 or so for a reflash.
-Michael
Old Feb 5, 2009 | 09:12 AM
-Michael
$500 for each reflash
i think that is possible convert from OBD II to CANBUS without spend a grand
down here in Puerto Rico a lot of people convert their cars from OBDI to OBDII and they dont spend a grant
how convenient is that sentence for you..... that smell $$$$$ for u
bottom end... for me the reflash may work but is too expensive for a person who is trying new setups and looking for the maximum in their , and the tune that you put in the ECU will not work good everywhere cause the weather and location
Old Feb 5, 2009 | 12:15 PM
hackish's Avatar
Before you criticise please educate yourself as to what CAN is. One of the expensive parts of a vehicle is the wiring harness. It takes the OEM a long time to construct, test and install these harnesses. CAN is a system designed to replace a lot of wiring by sending signals around to different devices.
It's like running one wire to a bunch of things and by sending high speed digital signals it can make everything work. The old way would be to run a wire from the tach to the coil, the speedometer signal from the transmission (via ECU), a wire to the coolant sensor etc etc etc. The new way is that the computer tells the cluster, "hey tach, show 4000 RPM, hey speedo, show 60mph, hey coolant gauge show 1/2 way up." All sent through the same wires.
How do you propose to make all these systems interface just by switching some wires around? What is $500 anyway? 6-8h of labour? The book probably pays 6h to re&re your dash!
-Michael
Old Feb 5, 2009 | 01:41 PM
-Michael
I said "I THINK"
anyway $500 each time I need to tune my car, plus send the ECU is no good...
Old Feb 7, 2009 | 08:08 AM
$MIVEC$'s Avatar
-Michael
Thing is your talking about prices for something that is not proven, not even done and will not be reliable from most people who buy since you will probably have a preset tune for sale. Maybe you should talk about ripping people off $500 after a RA actually has been reflashed
Old Feb 7, 2009 | 10:01 AM
Fifty's Avatar
^Ouch dude, comments like that are not needed. We have very limited support in the aftermarket so if someone wants to build a product for this model let them. So many companies sell flashes for roughly that price an no one complains so why is this community complaning when there maybe a new product for us?
Old Feb 7, 2009 | 10:09 PM
HondaHunter78's Avatar
Ok so here is the deal CANBus is how the system communicates. Its like Centrino the ECU still utilizes the ODB II port. CAN Bus is the way it talks. The ECU once it fires up talks to many processors that all process individul things. Its like having a network of multiple computers in the car. Now even if the RA was CANBus which I don't know if it is or not. No it is not possible it is not even possible for us to switch ECU's between Eclipse's. Mitsubishi keyed em. Every CANBus processor and the ECU are all imprinted with the Same key. If you switch the ECU and the key doesn't verify or match with everything else the Car will not work. If you want a new ECU it has to be flashed by Mitsu in order to operate with your particular Eclipse. Hope this answer's your question I guess the short answer would be NO. However the new ECUFlash program from openecu.org supports the H8 processor and CANBus. So even if your vehicles aren't CAN I would almost bet money they have H8 processor which is what was uncrackable.
Brownie614
Feb 26, 2012 07:57 AM
4GMivec69
Oct 11, 2010 01:12 AM
redefinescience
09+ Ralliart Show and Shine
20
Aug 21, 2010 01:52 PM
vasay1992
16
Aug 17, 2009 07:48 PM
NathanV
Mar 29, 2009 09:53 PM
