09+ Ralliart Show and Shine Post your pictures, photoshops, and videos!
Eclipse factory wheels
Old Jun 4, 2010 | 07:59 AM
redefinescience's Avatar
Hi All,
I'm a complete noob when it comes to wheels & tires and stuff.
Before i bought my wwRA, i was deciding between the eclipse and the RA,
i really like the factory wheels on the '10 eclipse and i wonder if they would fit nicely on the RA.
RA:
Wheel Size 18 in.
Tire Size 215/45R18
Eclipse:
Wheel Type 18"x8.0"JJ Alloy
Tire Size P235/45R18 94V
From what i understand, this means the Eclipse wheels are 2cm wider, what does the 94V mean?
i would assume the lug spacing is the same since the wheel diameter is the same.
Thanks!
Old Jun 4, 2010 | 10:01 AM
03chi-town0Z's Avatar
94v is the load/speed rating of the tire rubber itself. yes the bolt pattern (5x114.3) is the same, though the overall diameter of the wheel has nothing to do with that really.
at stock ride height they are likely to cause rubbing issues in the rear over bumps or any time the rear suspension is put under a decent amount of load (ie. multiple passengers) making a fender roll very desirable if you are going to be running these wheels. if planning on lowering the car, it will be a must.
also, i just had a galant wheel off of a car a little while ago and when on the balancing machine, i checked the width and i thought it was 8.5 (i may be mistaken), so it should be the same for the eclipse if you are talking about the two-tone galant ralliart/eclipse gt or se rims. either way, 8 or 8.5 with the 235/45 tire, the above statements will hold true.
Old Jun 4, 2010 | 11:22 AM
DatRAzn's Avatar
Keep in mind also, that if you're going to be running 235/45, your speedometer will be off a little bit...
235/40 would be the closest to stock tire diameter with only a 0.8% too fast reading on the speedo.
Old Jun 4, 2010 | 12:01 PM
MisterG's Avatar
Are you talking about this wheel? If so, the specs are:
Enkei, 18x8, ET46
They are a direct fit. (same bolt pattern, hub size, uses the same stock lugs, same centercaps, and the OEM TPMS is completely transferable)
Old Jun 4, 2010 | 12:17 PM
So that would give me a similar diameter, would the extra width still be a concern with it rubbing?
Old Jul 13, 2010 | 08:12 PM
SOG RA's Avatar
There is a guy on here running those exact wheels on his RA
Old Jul 14, 2010 | 04:14 PM
SOG RA's Avatar
Look at the GG Ralliart thread under show and shine to see the rims on the car.
Old Jul 15, 2010 | 08:27 PM
gccruz's Avatar
Those could look nice
Old Jul 16, 2010 | 09:21 PM
Batman25's Avatar
Here you go.
Originally Posted by MisterG
Old Jul 16, 2010 | 11:24 PM
ck1109's Avatar
They do look nice. Does tirerack or some other online retailer sell them?
Old Jul 17, 2010 | 12:43 AM
SOG RA's Avatar
Buy em on Ebay! They got them on there for $400.
Old Jul 17, 2010 | 05:09 PM
bacquerel's Avatar
^ the eclipse rims?? i kinda want that now. =)
Old Jul 18, 2010 | 04:24 AM
MisterG's Avatar
Old Aug 1, 2010 | 11:42 AM
gts2010's Avatar
hi
rings will look great eclipse rallairt a lancer gts 2010, where I can get the window trim choremo someone can give me information
Old Aug 2, 2010 | 06:25 AM
ck1109's Avatar
You've installed the Eibach Pro-kit springs, right? Did you need to roll your fenders after the drop?
Have you weighed these wheels as well? Are they lighter than stock?
