04-06 Ralliart Engine/Drivetrain (no forced induction)
small piggyback ecu problem
Old Mar 7, 2009 | 04:58 AM
RA032924's Avatar
I just installed my piggyback ECU on my 06 RA AT. The connections are fine, I soldered the cut wire, and used the connectors given by RRM for the other 3 wires. I followed the instructions letting the car idle and driving it conservatively.
However, after a day the car seems to be revving by itself when idling. Is this normal? It is revving up to 1000-1500 randomly.
My car only has an injen CAI and RRM pulley installed. Is it just that it isn't tuned correctly for my car and that the sensor for airflow is off? What can I do to fix this?
Old Mar 7, 2009 | 07:24 AM
Raikiri's Avatar
Did you reset the ECU?
Old Mar 7, 2009 | 09:41 AM
Ralli///Art's Avatar
I think most RA had always had that idle from around 1000 to 1500, but only for a few minutes after startup. I've noticed also that my car also does that from time to time long after warming up. Regardless of it, I also suggest that you reset your ECU.
Old Mar 7, 2009 | 09:45 AM
Raikiri's Avatar
some reason my idle is around 750-1000 without a piggyback.... do i need to reset mine?
Old Mar 7, 2009 | 09:49 AM
joeyj's Avatar
rule of thumb, after and kind of modification, whether it be electrical, bolt on, or even a bumper sticker, ALWAYS reset your ecu after the install!
Old Mar 7, 2009 | 02:32 PM
RA032924's Avatar
by resetting if u mean after i reattach the batter and let it idle to "learn" then yes i did that... do it have to reset a second time?
Old Mar 7, 2009 | 06:39 PM
joeyj's Avatar
no, but after you let it idle, did you drive it very conservatively never going into WOT, and keeping it under 3k rpm for 15 mins?
Old Mar 7, 2009 | 08:53 PM
RA032924's Avatar
yup i did that and then when i started it up later that day to go to work i noticed that it was doing this... i can try to reset it again, but i bet it will still be the same since i did everything correctly the first time. any other ideas?
oh it seems that after driving for a bit it stops, or its at least not as noticeable.
livelyjay
Nov 11, 2013 03:58 PM
Jogenmaru
Lancer Troubleshooting
Mar 2, 2010 10:52 AM
sonic_evox
Nov 16, 2009 10:26 PM
TEJ
Lancer Engine Management / Tuning Forums
12
Dec 22, 2005 06:55 AM
grubiaco
Nov 22, 2004 12:39 PM
