04-06 Ralliart Engine/Drivetrain (no forced induction)
oil temp guage install leaking help
Old Jun 17, 2009 | 06:18 PM
Gooseman396's Avatar
so as a result of the issues i have been having with my oil system i decided to install a oil pressure and temp guage. the temp guage came with a variety of drain plug sizes. i found the one that matched my RA and everythong went fine. after my first test drive i parked it and left it when i came back some time later there was a oil puddle under the drain hole it was not hudge but big enough. the problem is the fitting is brass and im afraid to tighten it down to much. i put teflon on the threads before the install. does anyone know where i can buy a new steel fitting that still has the hollow center for the thermometer? what is everyone else using? i cant see using this brass piece and taking it out every oil change its going to break at some point. thanks for the input.
Old Jun 17, 2009 | 06:23 PM
otter's Avatar
EvoM Administrator
Which hole did you use and did you use a BSPT adapter or NPT?
Old Jun 17, 2009 | 06:36 PM
i put it in the oil drain hole. as for bspt or npt not sure i used the hardware that came with it i do know there was no stripping of the threads so i assumed it was correct maybe not
Old Jun 17, 2009 | 07:02 PM
otter's Avatar
EvoM Administrator
Ah, if you put it in the oil drain hole, did you use a new crush washer?
Old Jun 17, 2009 | 07:37 PM
no i did not that might be my problem should i move it to a different location or will the crush washer fix the problem? i realy dont want to keep taking that out for each oil change? where are the other places i can put it?
Old Jun 18, 2009 | 01:16 PM
RalliDew's Avatar
You should not put a steel fitting into the aluminum block it makes it to easy to mess up the block. as for the crush washer thats a key parts but you could also just use quick dissconnect fittings to insure it wont leak and for removability. you can put it onto the back of the block under the intake manifold, you can ether T off the oil light sensor or jsut unplug the sensor for the oil light and put your fitting in the hole from oil light sender switch.
opps sry i was refering to the pressure gauge leaking. but i suppose you could just T off the oil light for that to.
Old Jun 18, 2009 | 07:41 PM
thanks for the reply guys. I went up to the local mitu dealer and picked up a crush washer. put it on there making sure not to tighten the brass fitting to much. Seems to be leak free now. thanks again.
honda-guy
28
Jan 30, 2021 08:48 PM
Brokeassevo
Aug 31, 2016 09:23 PM
ak47po
33
Mar 21, 2016 11:31 AM
EvoIXMR
Nov 25, 2008 05:59 PM
JJsEvo8
May 26, 2008 02:02 PM
