04-06 Ralliart Engine/Drivetrain (no forced induction)
Starter Motor Wire
Old Dec 22, 2009 | 09:01 AM
Ralliartize It's Avatar
My problem is exactly as this person's in the first article on this web page:
http://www.2carpros.com/topics/neutral.htm
Old Dec 22, 2009 | 09:14 AM
RalliDew's Avatar
Originally Posted by Ralliartize It
I checked the starter relay fuse with a tester and that seems to be ok. Shoudl I just replace it for the heck of it?
i dont think that would hurt cause it might be flutering
is your car auto
if its not auto then it would be the clutch switch.
try starting it it neutral if park doesnt work. and you can always check the switch it should be close to the linkage on the trany
IM me if you have AIM
Old Dec 22, 2009 | 09:54 AM
The car is 5spd. Sometimes it will start, sometimes it won't. AFter awhile it will start, exact symptoms as the pT cruiser. I thought the clutch switch was under the clutch pedal?
Old Dec 22, 2009 | 09:56 AM
RalliDew's Avatar
it is under there for the clutch not the auto the auto is off the tranny
sound more like your battery might be takinga dumop or you have a bad ground witch could happend cause the starter gets its ground from bolting to the tranny witch has a ground wire on it so make sure thats good to go
Old Dec 22, 2009 | 10:59 AM
I already replaced the battery as well. All grounds are good to go as well.
Old Jan 15, 2010 | 01:51 PM
RalliDew's Avatar
still having this problem?
Old Jan 15, 2010 | 09:42 PM
Knock on wood this problem seems to have remedied itself.
Old Feb 10, 2010 | 06:27 AM
Def the neutral safety switch, happened yesterday again, I fiddled with the switch and it started right away.
Old Jan 27, 2011 | 07:10 PM
Resurrected RA's Avatar
Thread resurrection!
Thank you for this!! Yet another thing that the mechanic that did the R&R on my car may have effed up. I will have to look into this on the weekend.
Old Jan 27, 2011 | 07:26 PM
lancerralli06's Avatar
how do these terminals and wires go bad or need replacing?
Old Jan 28, 2011 | 04:19 AM
I figured out my problem. My throwout bearing was having intermittent engagement problems. I would have to pump the clutch a few times then it would finally grab. ****ing bull****.
Old Jan 28, 2011 | 04:25 AM
Flip's Avatar
yea, id be pretty mad about that too bro, thats kinda ****ty. at least you found the problem, just going to switch it out?
-Flip
Old Jan 28, 2011 | 10:31 AM
Already did about two months ago after it took me over a year to figure out the ****ing problem!!!
fjm9898
Jun 20, 2016 10:12 AM
fast03evo
Oct 25, 2013 09:57 AM
Robdeep3
Jul 29, 2013 01:53 PM
eusgen
Lancer How Tos / Installations
Jun 25, 2012 06:44 PM
maxsideburn
Jun 7, 2010 07:08 AM
