So just a little problem.
I have a 05 ralliart, just something i noticed when im driving/ step on the gas pedal it sounds like a whistling noise coming from the engine, and then when the it switches gears it sounds like there is a CAI in the car but there isn't, makes a weird air noise.Does it after every shift of gear too. Any ideas what this might be?
as for the whistling, I get a kind of whining noise when it is cold out that kind of sounds like straight cut gears, just not as loud. I'm thinking it's the belts or something. not sure though.
The intake whistles all the time in my car , sounds like a turbo spoolin lol . I think you should look there , the only way to get rid of it is to cause more restriction on the intake, and who wants to do that. GL
I had the same whistling u described and then my balance shaft belt blew caught my timing belt shredded it and then slammed my piston into all intake valves but I was way passed due for a belt change so if ur passed due don't romp it lol
