04-06 Ralliart Engine/Drivetrain (no forced induction)
Transmission Question
Old Jun 2, 2010 | 05:15 AM
bboysyck's Avatar
I want to change my transmission from an automatic to a manual, is there some place where i can get the equipment needed?
Old Jun 2, 2010 | 08:04 AM
Ralliartize It's Avatar
Not sure if this has been done on the RA before but at minimum you need.
Shifter
Shifter Console
Shifter Cables
Clutch
Flywheel
Possibly new axles - Our driver's side axle has a bearing in it that mounts to the manual transmission
Manual ECU
Possible custom work to the car's body to make the the tranny doesn't hit anything.
Not sure if it's been done but these are possible things I can think of that you'd need.
Old Jun 2, 2010 | 10:46 AM
lanzerralliart's Avatar
EvoM Super Moderator
I wouldn't waste your time. By the time your done you probably could of just sold yours and get a mt ralliart. I bet you'd even save money going this route.
Old Jun 2, 2010 | 02:33 PM
Not many of these cars were made so sourcing the correct transmission could be pricey.
