04 Ralliart Gear oil / gearbox
does anyone know where the gearbox / gear oil is located in this car? i want to check the oil cause the car does not shift into gears well sometimes
Are you the first owner? If not I would definately do it as I have found most people do not change the tranny fluid at the recommended 30K. I think 75W90 is the recommended oil. I use redline MT90. Others like BG Sycroshift. Otter know which syncromesh/sycroshift fluid works best.
I've been using GM Synchromesh in my RA since the first time I changed the fluid. Almost 100k later, I'm still happy with it. Others have had good results with BG Synchroshift or Redline fluids.
Whatever you do, DO NOT use Mobil1 synthetic gear lube. It's too slippery, and will make for notchy, difficult shifting.
thanks everyone for their input especially Myszkewicz for the pics. I put in pennzoil synchromesh and the shifting is better but i'm going to try BG synchroshift II next
