04-06 Ralliart Engine/Drivetrain (no forced induction)
4g69 to 4g69 swap
Old Feb 19, 2011 | 06:06 PM
mmoulton470's Avatar
Ok, the guy at the local auto parts store says it's called a Dowel pin and that probably the only place I can get it is from a dealer (I can't find it anywhere online), so I'll check the local dealer after the weekend.. Anyone know whether Dowel pins need to be pressed in or should I just be able to tap it in with a hammer?
Old Feb 20, 2011 | 02:53 AM
lanzerralliart's Avatar
EvoM Super Moderator
You can find them at a true value / ace hardware store really cheap like 25 cents...
Old Feb 20, 2011 | 07:34 AM
RalliartN's Avatar
Dowel pins are a tight slip fit into an accurately reamed hole. When new you can push or gently tap them in. If you are trying to remove and a bit of corrosion has formed, give it a blast of penetrating oil and twist out with vice-grips or pliers.
Old Feb 24, 2011 | 08:17 PM
I haven't made it to the hardware store yet, but I'm sure they will have it. I painted up my oem headers and oil pan with some high heat paint and am still waiting for the motor mounts from RRM. The oil pan didn't have a gasket, only sealer.. Is that normal or should I get a gasket for it when I put it back on? I think a gasket is like 13 bucks from advance auto parts.
Old Feb 25, 2011 | 08:40 AM
xmaster19's Avatar
No gaskets for our cars. Only sealant. I can bet you 200$ that the only thing you'll fing in the ''gasket'' box will be a tube of sealant :P
Old Feb 25, 2011 | 09:05 AM
Haha.. I had a feeling that was the case... The best sealant for the job would be?
Old Feb 25, 2011 | 09:20 AM
CrAnSwIcK's Avatar
i use permatex ultra blue, or hi temp (red) depending on the application...
Old Feb 25, 2011 | 09:30 AM
kayouu's Avatar
They do make gaskets for the Oil pan, I just used sealer though too.
Old Mar 1, 2011 | 03:14 PM
I got some permatex for the oil pan.. Is there a specific bolt pattern?
Old Mar 2, 2011 | 04:28 PM
Am I right in saying this is the clutch release bearing? The grease left on it is old and dried up.. i'm assuming I should probably slab a healthy amount of fresh grease on there?
Old Mar 4, 2011 | 09:22 PM
Ok, everything is put back together and all fluids filled. The clutch feels like t isn't engaging for some reason.. When the car is off it goes into gear but when it is on I can't get it in gear at all.. Anyone know what may be causing this?
Old Mar 5, 2011 | 10:15 AM
Bled the slave cylinder and it works perfectly. Taking the new engine out for it's maiden voyage now.
Old Mar 5, 2011 | 08:17 PM
k3lv's Avatar
good to know you got it going without any further issues. Cheers
Old Mar 6, 2011 | 06:48 PM
veloracer's Avatar
awesome dude, hope it all feels good.
Old Mar 6, 2011 | 08:21 PM
Thanks guys. Yeah it feels awesome! Even better than my old motor, and I think the solid mounts really make a difference. I'm so glad I decided to replace the motor rather than to junk the car. Now I need to start modding! First will come a lip and hood though I think because my stock lip is broken and my hood has a bad rust spot.
jb988
Lancer Engine Tech
35
Dec 19, 2017 09:12 PM
Sheroku
Lancer Engine Tech
Mar 23, 2016 11:25 AM
Ibrahim Nabil
Aug 6, 2015 05:22 PM
TrevRoar
Apr 13, 2015 10:59 PM
Kasper
Feb 19, 2015 11:48 AM
